跳转到主内容
How to Repair Undone Permanent Pleats in a Pleated Skirt
你所需要的
  1. How to Repair Undone Permanent Pleats in a Pleated Skirt, How to Repair Undone Permanent Pleats in a Pleated Skirt: 步骤 1 中的图像 1,3 How to Repair Undone Permanent Pleats in a Pleated Skirt, How to Repair Undone Permanent Pleats in a Pleated Skirt: 步骤 1 中的图像 2,3 How to Repair Undone Permanent Pleats in a Pleated Skirt, How to Repair Undone Permanent Pleats in a Pleated Skirt: 步骤 1 中的图像 3,3
    • Lay the skirt on a flat surface and fold the undone pleat into place.
    • Pin the pleat into place with a sewing pin or pins, pinning near the top of the pleat at the waistline of the skirt.
    • Caution: This guide uses sewing pins and sewing needles. Please remember to be careful when using these tools as they are sharp and can cause minor cuts.
  2. How to Repair Undone Permanent Pleats in a Pleated Skirt: 步骤 2 中的图像 1,3 How to Repair Undone Permanent Pleats in a Pleated Skirt: 步骤 2 中的图像 2,3 How to Repair Undone Permanent Pleats in a Pleated Skirt: 步骤 2 中的图像 3,3
    • Select thread of a color that matches the color of the skirt.
    • Put the thread through the eye (hole) of the needle.
    • Knot the thread at the eye (hole) of the needle.
  3. How to Repair Undone Permanent Pleats in a Pleated Skirt: 步骤 3 中的图像 1,3 How to Repair Undone Permanent Pleats in a Pleated Skirt: 步骤 3 中的图像 2,3 How to Repair Undone Permanent Pleats in a Pleated Skirt: 步骤 3 中的图像 3,3
    • Begin sewing by pushing the needle through the skirt, starting with the needle on the inside of the skirt.
    • Starting on the inside of the skirt ensures no extra thread is exposed on the exterior of the skirt once the repair is complete.
    • Leave approximately 10 cm to 15 cm of thread on the inside of the skirt.
    • You do not want to pull the thread completely through the hole as this would not allow you to form any stitches while sewing.
  4. How to Repair Undone Permanent Pleats in a Pleated Skirt: 步骤 4 中的图像 1,2 How to Repair Undone Permanent Pleats in a Pleated Skirt: 步骤 4 中的图像 2,2
    • Complete the first stich along the top of the pleat, making the stitch approximately 0.25 cm.
    • Continue stitching in and out of the skirt until the end of the undone pleat is reached.
  5. How to Repair Undone Permanent Pleats in a Pleated Skirt: 步骤 5 中的图像 1,1
    • Stitch in the opposite direction until the needle is back where it started.
    • By stitching in the opposite direction the repair will be strengthened.
  6. How to Repair Undone Permanent Pleats in a Pleated Skirt: 步骤 6 中的图像 1,3 How to Repair Undone Permanent Pleats in a Pleated Skirt: 步骤 6 中的图像 2,3 How to Repair Undone Permanent Pleats in a Pleated Skirt: 步骤 6 中的图像 3,3
    • Complete one final stitch so that the needle is on the inside of the skirt.
    • Cut the thread with scissors leaving about 10 cm to 15 cm of thread.
  7. How to Repair Undone Permanent Pleats in a Pleated Skirt: 步骤 7 中的图像 1,3 How to Repair Undone Permanent Pleats in a Pleated Skirt: 步骤 7 中的图像 2,3 How to Repair Undone Permanent Pleats in a Pleated Skirt: 步骤 7 中的图像 3,3
    • Knot the two loose pieces of thread on the inside of the skirt.
    • One piece of thread comes from Step 3 and the other from Step 6.
    • Cut any excess threads with scissors.
  8. How to Repair Undone Permanent Pleats in a Pleated Skirt: 步骤 8 中的图像 1,2 How to Repair Undone Permanent Pleats in a Pleated Skirt: 步骤 8 中的图像 2,2
    • Remove the sewing pin or pins.
结论
Your repair is complete! Repeat this guide for additional undone pleats.
Camille Gildersleeve
于02/20/24注册
157 声望
撰写一个指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 12
过去 30 天: 33
总计 101
