跳转到主内容
How to Repair Timex t121b Buttons
你所需要的
  1. How to Repair Timex t121b Buttons, How to Repair Timex t121b Buttons: 步骤 1 中的图像 1,3 How to Repair Timex t121b Buttons, How to Repair Timex t121b Buttons: 步骤 1 中的图像 2,3 How to Repair Timex t121b Buttons, How to Repair Timex t121b Buttons: 步骤 1 中的图像 3,3
    • Unplug the alarm clock from the power.
    • Flip the alarm clock upside down and open the lid.
    • Take out the batteries and leave them aside.
  2. How to Repair Timex t121b Buttons: 步骤 2 中的图像 1,3 How to Repair Timex t121b Buttons: 步骤 2 中的图像 2,3 How to Repair Timex t121b Buttons: 步骤 2 中的图像 3,3
    • Use a Phillips screwdriver to remove all of the screws on the underside of the clock.
    • Carefully lift the cover and lay it down as shown in the third image.
  3. How to Repair Timex t121b Buttons: 步骤 3 中的图像 1,3 How to Repair Timex t121b Buttons: 步骤 3 中的图像 2,3 How to Repair Timex t121b Buttons: 步骤 3 中的图像 3,3
    • Flip the alarm clock until the top of the clock is facing down.
    • Take out the first screw (1.2 mm Phillips) as shown in the second image.
    • Take out the second screw (1.2 mm Phillips) as shown in the third image.
  4. How to Repair Timex t121b Buttons: 步骤 4 中的图像 1,3 How to Repair Timex t121b Buttons: 步骤 4 中的图像 2,3 How to Repair Timex t121b Buttons: 步骤 4 中的图像 3,3
    • Carefully check the buttons and make sure you are able to press all the buttons.
    • Clean any dust that might be interfering with the buttons.
    • Adjust and push the alarm slide button to its proper position as shown in the third image.
  5. How to Repair Timex t121b Buttons: 步骤 5 中的图像 1,3 How to Repair Timex t121b Buttons: 步骤 5 中的图像 2,3 How to Repair Timex t121b Buttons: 步骤 5 中的图像 3,3
    • Put the board back in place and place the first screw (1.2 mm Phillips) as shown in the first image.
    • Place the second screw (1.2 mm Phillips) as shown in the second image.
    • Carefully place the two halves of the clock back together and put all 4 screws (1.2 mm Phillips) as shown in the third image.
    • Open the back lid and place the batteries.
结论
2等其他人完成本指南。
Jad Abdalnor
于01/18/22注册
169 声望
撰写一个指南
团队
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 16
总计 714
