跳转到主内容
How to Repair Scratches in Laminate Finish Furniture
你所需要的
  1. How to Repair Scratches in Laminate Finish Furniture, How to Repair Scratches in Laminate Finish Furniture: 步骤 1 中的图像 1,1
    • Clean the scratched area with a damp cloth or paper towel to remove any dust or debris.
  2. How to Repair Scratches in Laminate Finish Furniture: 步骤 2 中的图像 1,1
    • Apply a small amount of wood filler to a putty knife.
    • The amount of wood filler needed may vary depending on severity of the scratches.
  3. How to Repair Scratches in Laminate Finish Furniture: 步骤 3 中的图像 1,1
    • Spread the wood filler over the scratches using the putty knife until they are sufficiently filled in.
    • The putty knife can be used to scrape away excess wood filler and smooth the surface.
  4. How to Repair Scratches in Laminate Finish Furniture: 步骤 4 中的图像 1,1
    • Wipe away any residual wood filler from the surface using a damp cloth or paper towel.
  5. How to Repair Scratches in Laminate Finish Furniture: 步骤 5 中的图像 1,1
    • Allow the wood filler to dry completely based on the package instructions before resuming use.
  6. How to Repair Scratches in Laminate Finish Furniture: 步骤 6 中的图像 1,1
    • Sand over the wood filler using fine-grit sandpaper if a smoother finish is desired.
  7. How to Repair Scratches in Laminate Finish Furniture: 步骤 7 中的图像 1,1
    • Paint over the wood filler, if desired, to color match the filler with the furniture.
    • Wood filler comes in a variety of colors so painting may not be necessary.
终点
Shelby
于02/20/24注册
145 声望
撰写一个指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 9
过去 30 天: 24
总计 45
