简介
The purpose of this guide is to help with the common issue first time builders face, that of accidentally breaking a piece of your kit. Through this guide you will be able to fix any would-be mistakes you might have made during building. Thankfully, there are no particular hazards, so there’s no need to worry about any potential dangers during the repair process. Just take each step slow, and you’ll have a repaired part in no time.
你所需要的
Identify the original look of your part. This can most easily be done by simply taking the two broken pieces and fitting them together, but if needed, consult the instruction manual that came with your model kit.
Grab one of the empty plastic frames (runners) that came with your kit, preferably one of the same color as your piece.
File or clip down a piece of the runner to use as support.
In this guide, we will be clipping the part for support as the piece is too small to fit a filed down support piece.
Wait for the glue to dry and you’ll be able to build with it as intended.
另外一个人完成了本指南。
