跳转到主内容
加入维修社区 - 创建账户
How to Repair Nylon Shorts
你所需要的
  1. How to Repair Nylon Shorts, How to Repair Nylon Shorts: 步骤 1 中的图像 1,1
    • Be sure to choose a thread color that is similar to the garment you are repairing.
    • Thread the needle by stringing the thread through the eye of the needle.
    • Knot the end of the thread and cut off any excess thread. The knot should be large enough to catch the fabric and not pull through.
  2. How to Repair Nylon Shorts: 步骤 2 中的图像 1,1
    • Take the torn seam into both hands, and overlap one side with the other until both sides are aligned.
  3. How to Repair Nylon Shorts: 步骤 3 中的图像 1,1
    • Starting from the inside of the garment, pull the needle through the fabric.
    • Pull the thread until the knot catches the fabric.
  4. How to Repair Nylon Shorts: 步骤 4 中的图像 1,1
    • Make small stitches along the length of the rip.
    • Do not pull the thread too tight or it will cause rippling in the fabric.
  5. How to Repair Nylon Shorts: 步骤 5 中的图像 1,1
    • Tie the thread as close to the fabric as possible.
    • Cut off any extra thread that is still attached.
结论
This guide can be applied to any piece of clothing that has a rip in the seam. Happy stitching!
另外一个人完成了本指南。
Rachel Brockett
于10/12/18注册
145 声望
撰写一个指南
团队
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 7
过去 7 天: 16
过去 30 天: 61
总计 3,233
