跳转到主内容
How to Repair Molded Baseboards
你所需要的
  1. How to Repair Molded Baseboards, How to Repair Molded Baseboards: 步骤 1 中的图像 1,1
    • Sand the damaged area with the 120 grit sandpaper or a sanding block.
    • Use a utility knife to smooth rougher areas if needed.
  2. How to Repair Molded Baseboards: 步骤 2 中的图像 1,1
    • Lightly coat the damaged area with wood glue.
  3. How to Repair Molded Baseboards: 步骤 3 中的图像 1,2 How to Repair Molded Baseboards: 步骤 3 中的图像 2,2
    • Build up the affected areas with the wood filler. This can be applied with your hands (as individual product safety allows), a spare piece of cardboard, or a popsicle stick.
    • Allow to dry a few hours or overnight (based on product directions).
  4. How to Repair Molded Baseboards: 步骤 4 中的图像 1,1
    • Cut or fold the 150 grit sandpaper sheet into various pieces to allow proper fit into the various grooves of your baseboard.
  5. How to Repair Molded Baseboards: 步骤 5 中的图像 1,1
    • Sand the dried wood filler with 150 grit sandpaper.
    • Start from the inside of the baseboard and move out toward the repaired area.
    • Avoid a sawing or back-and-forth motion with the sandpaper to achieve a smooth finish.
  6. How to Repair Molded Baseboards: 步骤 6 中的图像 1,1
    • Wipe with a slightly damp cloth.
    • Repeat step 3 as needed.
    • Wait at least one hour.
    • Repeat step 6 for the final sanding.
  7. How to Repair Molded Baseboards: 步骤 7 中的图像 1,1
    • Touch-up with matching paint as needed.
结论
Clean-up should be a breeze, and you should be ready to finish your weekend with loads of time to spare after this simple project!
2等其他人完成本指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 27
过去 30 天: 101
总计 10,888
