跳转到主内容
How to Repair Malfunctioning Cordless Window Blinds
你所需要的
  1. How to Repair Malfunctioning Cordless Window Blinds, How to Repair Malfunctioning Cordless Window Blinds: 步骤 1 中的图像 1,3 How to Repair Malfunctioning Cordless Window Blinds, How to Repair Malfunctioning Cordless Window Blinds: 步骤 1 中的图像 2,3 How to Repair Malfunctioning Cordless Window Blinds, How to Repair Malfunctioning Cordless Window Blinds: 步骤 1 中的图像 3,3
    • Remove the clips that keep the blinds attached to the wall.
    • These should easily slide out.
  2. How to Repair Malfunctioning Cordless Window Blinds: 步骤 2 中的图像 1,2 How to Repair Malfunctioning Cordless Window Blinds: 步骤 2 中的图像 2,2
    • Slide the angling rod off its hook.
  3. How to Repair Malfunctioning Cordless Window Blinds: 步骤 3 中的图像 1,1
    • Locate the pulley where the string exits the top housing.
    • The string has likely fallen off of the pulley, causing too much resistance for the retraction mechanism to work properly.
  4. How to Repair Malfunctioning Cordless Window Blinds: 步骤 4 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Pull the shaft partially out of the housing.
    • The shaft is not supposed to come out of the housing all of the way. This step is meant to bend the shaft just enough so that the tweezers can reach behind it.
  5. How to Repair Malfunctioning Cordless Window Blinds: 步骤 5 中的图像 1,1
    • From the bottom of the housing, pull on the string that runs through the blinds.
    • This step is meant to add slack in the string.
    • Hold the slack by putting a finger through the loop it makes.
  6. How to Repair Malfunctioning Cordless Window Blinds: 步骤 6 中的图像 1,1
    • While holding the slack with your middle finger, and the shaft with your index finger, use the tweezers to grab on to the string from the top side of the housing.
    • Pull the string up and toward you as you remove your middle finger from the loop.
  7. How to Repair Malfunctioning Cordless Window Blinds: 步骤 7 中的图像 1,2 How to Repair Malfunctioning Cordless Window Blinds: 步骤 7 中的图像 2,2
    • Test the blinds to see if they are working. If they aren't, check to see if the string has been realigned on the pulley and repeat the steps as necessary.
结论
Enjoy your retractable blinds!
Adam Porter
于02/26/22注册
145 声望
撰写一个指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 34
过去 7 天: 176
过去 30 天: 947
总计 26,104
