跳转到主内容
加入维修社区 - 创建账户
How to Repair Land Rover Range Rover that will not unlock
    • Open the back door and appy duct tape to the edges near the locking staple
    • Hold back the rubber trim and using a hacksaw blade cut the two sides of the staple, starting with the bar nearest you first
    • It will take some time (upto 1 hour!) but you will cut through it and the door will open
    • Remove the door card by removing the 3 screws - 1 on the door handle and two on the lower edge
    • Pull the card out to release the pop catches and then up away from the window strip
    • Disconnect all the wires and door handle - the panel will be free now.
    • Remove the door lock mechanism by unscrewing the 3 bolts and the external door catch
    • Using this guide, open the assembly and lubricate. Ensure that your mechanism works as shown in the video.
结论
另外一个人完成了本指南。
Andrew Armstrong
于05/23/18注册
706 声望
创作了5篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 9
过去 30 天: 37
总计 376
