简介
GPS signal repair
你所需要的
视频介绍
即将完成!
结论
一条评论
Hi sir, i have the exact same problem with GPS. At first i thought it’s a software problem so i tried every way i could find on the internet but none of them seem to work.
I read so many Zenfone user using your method solve the problem. I’d like to try it as well hoping my GPS will fixed.
My question is :
the GPS antenna separated in two parts which connected to two connectors. As i see the pics in your vid, do i have to connect only the upper part of antenna to the upper connector? and is it necessary to put the other end of cooper wire to the small hole below the sim card slot?
Any answer will be much appreciated.
Thank you from Bali
Vickkal Kristianes - 回复
