跳转到主内容
How to Repair Frayed Shoelaces
你所需要的
  1. How to Repair Frayed Shoelaces, How to Repair Frayed Shoelaces: 步骤 1 中的图像 1,1
    • Cut of the excess frayed shoelace.
  2. How to Repair Frayed Shoelaces: 步骤 2 中的图像 1,3 How to Repair Frayed Shoelaces: 步骤 2 中的图像 2,3 How to Repair Frayed Shoelaces: 步骤 2 中的图像 3,3
    • Slip the entire heat shrink tube over the frayed part of the lace.
    • Make sure to clump the frayed part of the lace together when inserting the tubing.
    • Do not cover too much of the lace that is not frayed with tubing as that could result in unwanted indents in the shoelace.
  3. How to Repair Frayed Shoelaces: 步骤 3 中的图像 1,2 How to Repair Frayed Shoelaces: 步骤 3 中的图像 2,2
    • After slipping the tube on, grab the scissors and trim the excess tubing to the length of your satisfaction.
    • Remember not to go beyond the frayed part of the lace with tubing.
  4. How to Repair Frayed Shoelaces: 步骤 4 中的图像 1,3 How to Repair Frayed Shoelaces: 步骤 4 中的图像 2,3 How to Repair Frayed Shoelaces: 步骤 4 中的图像 3,3
    • Now use the lighter and heat the heat shrink tube, about an inch away from the lace, until the tube becomes compressed all the way around.
    • Make sure to heat the heat shrink tube all the way around, heating the entire tube
    • When heating, always keep moving the lighter all around and not staying on one part of the tube for too long.
  5. How to Repair Frayed Shoelaces: 步骤 5 中的图像 1,1
    • Repeat these steps on all the other frayed shoelaces.
结论
When the heat shrink tube is completely shrunk to appropriate size, you are finished. Repeat steps 1-4 depending on how many frayed laces are present.
14等其他人完成本指南。
Anirudh Jain
于04/09/15注册
605 声望
撰写一个指南
团队
Cal Poly, Team 28-6, Green Spring 2015 Cal Poly, Team 28-6, Green Spring 2015 的会员
CPSU-GREEN-S15S28G6
4 名成员
创作了11篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 31
总计 12,472
