跳转到主内容
How to Repair Damaged Door or Window Casing
你所需要的
  1. How to Repair Damaged Door or Window Casing, How to Repair Damaged Door or Window Casing: 步骤 1 中的图像 1,1
    • Sand down the damaged area of the trim using the block sanding sponge to make a smooth surface.
  2. How to Repair Damaged Door or Window Casing: 步骤 2 中的图像 1,1
    • Wipe off the excess dust from sanding with a wash cloth.
  3. How to Repair Damaged Door or Window Casing: 步骤 3 中的图像 1,1
    • Apply Dap drydex spackling to to the damaged area of the trim using a 1" plastic putty knife.
    • Allow the spackling to dry per the directions on the label.
  4. How to Repair Damaged Door or Window Casing: 步骤 4 中的图像 1,1
    • Use the block sanding sponge to smooth out the surface of the trim to match the crevices of the trim.
  5. How to Repair Damaged Door or Window Casing: 步骤 5 中的图像 1,1
  6. How to Repair Damaged Door or Window Casing: 步骤 6 中的图像 1,2 How to Repair Damaged Door or Window Casing: 步骤 6 中的图像 2,2
    • Tape the edges around the damaged area of the trim with masking tape.
  7. How to Repair Damaged Door or Window Casing: 步骤 7 中的图像 1,2 How to Repair Damaged Door or Window Casing: 步骤 7 中的图像 2,2
    • Paint the trim to match the original color.
    • Allow the paint to dry before removing the tape.
结论
Repairing chipped and/or broken door or window casing in the home as a do-it-yourself project overall saves time and money. There is no hassle of having to take off of work to meet the installers, no outrageous costs for materials and proper equipment, and no stress because this guide has everything necessary to complete the repair. So have fun, good luck, and happy fixing.
另外一个人完成了本指南。
Celeste Conroy
于07/11/17注册
128 声望
撰写一个指南
团队
Texas Tech, Team S1-G6, Rauch Summer 2017 Texas Tech, Team S1-G6, Rauch Summer 2017 的会员
TTU-RAUCH-SU17S1G6
3 名成员
创作了1篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 25
总计 2,597
