跳转到主内容
How to Repair Bumped Corners on a Hardcover Book
你所需要的
  1. How to Repair Bumped Corners on a Hardcover Book, How to Repair Bumped Corners on a Hardcover Book: 步骤 1 中的图像 1,1
    • Open the book to one cover corner.
    • Apply the PVA glue on a bumped corner using the glue tip or a small paintbrush.
    • Coat the worn layers with the same paintbrush.
    • The corner layers should be well-saturated for them to stick together.
  2. How to Repair Bumped Corners on a Hardcover Book: 步骤 2 中的图像 1,1
    • Pinch the corner layers together with a piece of cloth.
    • Remove excess glue with paper towels or a cloth rag.
    • Pinching the corner layers will help them stick together with the glue.
    • The cloth will provide minimal mess and remove excess glue.
  3. How to Repair Bumped Corners on a Hardcover Book: 步骤 3 中的图像 1,1
    • Wrap the entire corner with a small sheet of wax paper.
    • The wax paper will protect the work done on the corner for the next steps.
  4. How to Repair Bumped Corners on a Hardcover Book: 步骤 4 中的图像 1,1
    • Put one piece of wood chipboard on each side of the corner.
    • The wood chipboard will prevent the book corner from denting in the next step.
  5. How to Repair Bumped Corners on a Hardcover Book: 步骤 5 中的图像 1,1
    • Clamp everything together.
    • Let everything dry for 30 minutes.
    • This book-binding method ensures enough time and support for the bumped corner to transform into better condition.
  6. How to Repair Bumped Corners on a Hardcover Book: 步骤 6 中的图像 1,2 How to Repair Bumped Corners on a Hardcover Book: 步骤 6 中的图像 2,2
    • Remove the clip, boards, and wax paper to see the results.
    • Repeat steps 1-6 for any other bumped book corner(s).
结论
And that's bookbinding! Enjoy your book in new condition.
2等其他人完成本指南。
Salimah Rogers
于04/22/24注册
160 声望
撰写一个指南
团队
UC Davis, Team 3-6, Whithaus Spring 2024 UC Davis, Team 3-6, Whithaus Spring 2024 的会员
UCD-WHITHAUS-S24S3G6
3 名成员
创作了1篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 7
过去 7 天: 24
过去 30 天: 63
总计 162
