跳转到主内容
加入维修社区 - 创建账户
How to Repair Automobile Scratches & Paint Chips
你所需要的
    1. How to Repair Automobile Scratches & Paint Chips, How to Repair Automobile Scratches & Paint Chips: 步骤 1 中的图像 1,1
      • Check the inside of the driver's side door to find the manufacturer's paint code.
      • This sticker can be found directly next to the VIN number.
      • Use this paint code to order the exact same color paint online or find it at your local hardware store.
      询问修复机器人
      添加评论
    2. How to Repair Automobile Scratches & Paint Chips: 步骤 2 中的图像 1,1
      • Fill a medium-sized bucket with warm water and a small amount of soap.
      • A little soap goes a long way.
      询问修复机器人
      添加评论
    3. How to Repair Automobile Scratches & Paint Chips: 步骤 3 中的图像 1,3 How to Repair Automobile Scratches & Paint Chips: 步骤 3 中的图像 2,3 How to Repair Automobile Scratches & Paint Chips: 步骤 3 中的图像 3,3
      • Use soapy water and sponge to wash the car.
      • Rinse off the soap with a water hose.
      询问修复机器人
      添加评论
    4. How to Repair Automobile Scratches & Paint Chips: 步骤 4 中的图像 1,1
      • Use a clean towel to dry the freshly washed car.
      • Make sure the area is completely dry before continuing.
      询问修复机器人
      添加评论
    5. How to Repair Automobile Scratches & Paint Chips: 步骤 5 中的图像 1,1
      • Use sandpaper to buff out scratches. Start from 150 and continue until 400 grit.
      • This levels out the area so the paint will be applied evenly.
      询问修复机器人
      添加评论
    6. How to Repair Automobile Scratches & Paint Chips: 步骤 6 中的图像 1,2 How to Repair Automobile Scratches & Paint Chips: 步骤 6 中的图像 2,2
      • Use a small amount of grease remover and a cloth to clean any wax from the area.
      询问修复机器人
      添加评论
    7. How to Repair Automobile Scratches & Paint Chips: 步骤 7 中的图像 1,2 How to Repair Automobile Scratches & Paint Chips: 步骤 7 中的图像 2,2
      • Starting with a small amount of paint, apply the first coat of paint to the scratched area.
      • Use as little paint as possible to prevent clumping.
      • Wait 15-20 minutes for the coat to fully dry before continuing.
      询问修复机器人
      添加评论
    8. How to Repair Automobile Scratches & Paint Chips: 步骤 8 中的图像 1,2 How to Repair Automobile Scratches & Paint Chips: 步骤 8 中的图像 2,2
      • If necessary, apply a second coat of paint to the area.
      • This may be necessary for deep scratches or chips.
      • Wait 15-20 minutes before continuing.
      • Continue to reapply if needed.
      询问修复机器人
      添加评论
    9. How to Repair Automobile Scratches & Paint Chips: 步骤 9 中的图像 1,3 How to Repair Automobile Scratches & Paint Chips: 步骤 9 中的图像 2,3 How to Repair Automobile Scratches & Paint Chips: 步骤 9 中的图像 3,3
      • Use the small paintbrush to apply clear coat over the freshly dried paint.
      • Wait 10-15 minutes for the clear coat to dry.
      询问修复机器人
      添加评论
    10. How to Repair Automobile Scratches & Paint Chips: 步骤 10 中的图像 1,1
      • Give your car a quick look over to ensure you got every spot.
      • If you missed a spot, no worries. Just go through this guide again.
      • Now your car is as good as new!
      询问修复机器人
      添加评论
结论
After the clear coat has dried, your car’s paint job should be looking like it did the day you drove it off the lot!
取消:我没有完成这个指南。
4等其他人完成本指南。
1指南评论
Kann man die folgende Sonax Autopolitur für den 6. Schritt verwenden?
Engin Mutlu - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 11
过去 7 天: 59
过去 30 天: 195
总计 4,576
