跳转到主内容
How to Repair Arm Gapes
你所需要的
  1. How to Repair Arm Gapes, How to Repair Arm Gapes: 步骤 1 中的图像 1,1
    • Gather the supplies needed.
  2. How to Repair Arm Gapes: 步骤 2 中的图像 1,2 How to Repair Arm Gapes: 步骤 2 中的图像 2,2
    • Grab your measuring tape.
    • Measure from the middle of the breast to the under arm part.
  3. How to Repair Arm Gapes: 步骤 3 中的图像 1,3 How to Repair Arm Gapes: 步骤 3 中的图像 2,3 How to Repair Arm Gapes: 步骤 3 中的图像 3,3
    • Mark the middle of the breast and at the end where the under arm is. (Slide one and two)
    • Mark how big you want to close the gape. (Depends on how big your armhole gape is) (Slide three)
    • Mine was about 0.5 inches. (Slide three)
  4. How to Repair Arm Gapes: 步骤 4 中的图像 1,3 How to Repair Arm Gapes: 步骤 4 中的图像 2,3 How to Repair Arm Gapes: 步骤 4 中的图像 3,3
    • Connect both of the dots from the breast to the two dots you marked near the underarm.
    • Fold the second line you created and pin them to keep it coming from getting undone. (Slides two and three)
  5. How to Repair Arm Gapes: 步骤 5 中的图像 1,1
    • Sew across.
    • I used a straight sew stitch by hand (you can use a sewing machine and any stitch)
  6. How to Repair Arm Gapes: 步骤 6 中的图像 1,1
    • Lastly, cut the access off.
    • Then flip it inside out.
    • And your done!
结论
Thank you for taking the time to read this.
Danielle Fontanos
于10/23/23注册
133 声望
撰写一个指南
团队
CSU Los Angeles, Team 5-6, Kershman Fall 2023 CSU Los Angeles, Team 5-6, Kershman Fall 2023 的会员
CSULA-KERSHMAN-F23S5G6
1 名成员
创作了1篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 20
总计 108
