跳转到主内容
How to Repair A Hole In Curtains
你所需要的
  1. How to Repair A Hole In Curtains, How to Repair A Hole In Curtains: 步骤 1 中的图像 1,2 How to Repair A Hole In Curtains, How to Repair A Hole In Curtains: 步骤 1 中的图像 2,2
    • Examine the hole and open it gently so as to not cause any tearing.
    • Cut any loose threads that have frayed around the tear.
    • Be careful when using scissors. They are sharp and may cause injury.
  2. How to Repair A Hole In Curtains: 步骤 2 中的图像 1,2 How to Repair A Hole In Curtains: 步骤 2 中的图像 2,2
    • Use your scissors to cut a piece of fusible interfacing.
    • Make sure this piece is slightly larger than the hole in your curtain.
  3. How to Repair A Hole In Curtains: 步骤 3 中的图像 1,1
    • Place the ripped curtain face down on the ironing board.
  4. How to Repair A Hole In Curtains: 步骤 4 中的图像 1,2 How to Repair A Hole In Curtains: 步骤 4 中的图像 2,2
    • Place the fusible interfacing adhesive side down.
    • This side will have raised bumps on it
  5. How to Repair A Hole In Curtains: 步骤 5 中的图像 1,1
    • Preheat the iron to the temperature stated on the instructions for the fusible interfacing.
    • Some fusible interfacing may require either a steam setting or a dry setting.
  6. How to Repair A Hole In Curtains: 步骤 6 中的图像 1,3 How to Repair A Hole In Curtains: 步骤 6 中的图像 2,3 How to Repair A Hole In Curtains: 步骤 6 中的图像 3,3
    • Iron over the interfacing until it sticks to the fabric.
    • If the fabric is delicate you may want to place a protective cloth over the patch before ironing.
    • Be careful when using an iron. They can burn the fabric or cause serious injury.
结论
Now your curtain is as good as new! Fusible interfacing cannot be removed once it is attached to the fabric, so be careful when applying it so you can repair your curtains successfully.
Heather Brody
于03/29/21注册
133 声望
撰写一个指南
团队
Marist, Team S1-G4, Chaterdon Spring 2021 Marist, Team S1-G4, Chaterdon Spring 2021 的会员
MARS-CHATERDON-S21S1G4
3 名成员
创作了1篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 20
过去 30 天: 63
总计 2,329
