跳转到主内容
How to Repair A Broken Hip In A Plastic Doll
你所需要的
  1. How to Repair A Broken Hip In A Plastic Doll, How to Repair A Broken Hip In A Plastic Doll: 步骤 1 中的图像 1,2 How to Repair A Broken Hip In A Plastic Doll, How to Repair A Broken Hip In A Plastic Doll: 步骤 1 中的图像 2,2
    • Determine where your doll is broken: is it at the knee? Hip? Arm?
    • If it’s broken at the knee, as marked in the second photo, unfortunately this guide will not help as it is a different kind of joint.
  2. How to Repair A Broken Hip In A Plastic Doll: 步骤 2 中的图像 1,2 How to Repair A Broken Hip In A Plastic Doll: 步骤 2 中的图像 2,2
    • If the ball is still inside the leg, remove it with pliers.
  3. How to Repair A Broken Hip In A Plastic Doll: 步骤 3 中的图像 1,1
    • Hold one of the sewing pins with the pliers and heat the sewing pin with a lighter.
    • Do not leave fire unattended. The metal will be hot, so please don't touch it with your bare skin.
  4. How to Repair A Broken Hip In A Plastic Doll: 步骤 4 中的图像 1,1
    • With the hot sewing needle, make a small hole in the center of the broken off ball. Make sure the needle is straight.
    • This may take a few attempts and a few needles.
    • Heating up the plastic will result in some fumes. Perform this step in a well ventilated area.
  5. How to Repair A Broken Hip In A Plastic Doll: 步骤 5 中的图像 1,1
    • Hold one of the sewing pins with the pliers and heat the sewing pin with a lighter. (This is a repeat of Step 3.)
  6. How to Repair A Broken Hip In A Plastic Doll: 步骤 6 中的图像 1,2 How to Repair A Broken Hip In A Plastic Doll: 步骤 6 中的图像 2,2
    • With the hot sewing needle, make a small hole in the peg of the hip. Make sure the needle is straight. Leave the pin inside.
  7. How to Repair A Broken Hip In A Plastic Doll: 步骤 7 中的图像 1,2 How to Repair A Broken Hip In A Plastic Doll: 步骤 7 中的图像 2,2
    • Remove the pin from the broken off ball joint with a pair of pliers.
  8. How to Repair A Broken Hip In A Plastic Doll: 步骤 8 中的图像 1,2 How to Repair A Broken Hip In A Plastic Doll: 步骤 8 中的图像 2,2
    • Using the pliers, cut the pin in the hip section to the appropriate length to fit into the hole made from Step 6.
    • Test the needle length by fitting the ball joint pieces together. The needle should be completely covered.
    • The needle will go flying when you cut it, so direct it away from your face and other precious objects.
  9. How to Repair A Broken Hip In A Plastic Doll: 步骤 9 中的图像 1,1
    • Optional: remove any excess burnt plastic from the ball joint.
  10. How to Repair A Broken Hip In A Plastic Doll: 步骤 10 中的图像 1,3 How to Repair A Broken Hip In A Plastic Doll: 步骤 10 中的图像 2,3 How to Repair A Broken Hip In A Plastic Doll: 步骤 10 中的图像 3,3
    • Remove the pin from the hip and apply super glue to the end.
    • Insert the pin back into the hole.
    • When you reinsert the pin, some glue may come out. Leave it for Step 11.
  11. How to Repair A Broken Hip In A Plastic Doll: 步骤 11 中的图像 1,1
    • Push the ball onto the pin. Press together for 1 minute to set the glue.
    • The glue will set in 1 minute but it will take 24 hours to fully cure.
  12. How to Repair A Broken Hip In A Plastic Doll: 步骤 12 中的图像 1,1
    • Apply glue around the seam for extra reinforcement.
  13. How to Repair A Broken Hip In A Plastic Doll: 步骤 13 中的图像 1,2 How to Repair A Broken Hip In A Plastic Doll: 步骤 13 中的图像 2,2
    • Now with the ball joint secured into the pelvis, carefully pop the leg back into the hip.
    • The doll's leg should now move as normal!
结论
To reassemble your device, follow these instructions in order.
2等其他人完成本指南。
Lee Brunkhardt
于01/31/23注册
232 声望
撰写一个指南
团队
UC Davis, Team 3-1, Andersen Winter 2023 UC Davis, Team 3-1, Andersen Winter 2023 的会员
UCD-ANDERSEN-W23S3G1
5 名成员
创作了2篇指南
1指南评论
But is there a way you can attach the Barbie doll leg by just pushing the leg instead of doing all of that?
Amalachukwu - 回复
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 22
过去 30 天: 128
总计 3,837
