跳转到主内容
How to Repaint Your Garage Floor
你所需要的
  1. How to Repaint Your Garage Floor, How to Repaint Your Garage Floor: 步骤 1 中的图像 1,1
    • Use a paint scraper to remove the old paint from the area where you want to apply the new paint.
    • It's okay if there is still some old paint left on the surface.
    • Paint cracks usually indicate corrosion and require scraping.
  2. How to Repaint Your Garage Floor: 步骤 2 中的图像 1,1
    • Remove debris and dust with a broom.
  3. How to Repaint Your Garage Floor: 步骤 3 中的图像 1,1
    • Examine the quality of your paint.
    • If it is too thick, and you're using water-based paint, mix in a little bit of water.
    • If it is too thick, and you're using an oil-based paint, add paint thinner.
  4. How to Repaint Your Garage Floor: 步骤 4 中的图像 1,1
    • Wet the surface of the roller with water.
  5. How to Repaint Your Garage Floor: 步骤 5 中的图像 1,2 How to Repaint Your Garage Floor: 步骤 5 中的图像 2,2
    • Pour the paint in a container, dip your roller in, and start rolling.
    • You can also use a paint brush.
  6. How to Repaint Your Garage Floor: 步骤 6 中的图像 1,1
    • New paint has been applied and you can see the direct contrast.
    • When the paint has dried, reapply a second coat of paint.
  7. How to Repaint Your Garage Floor: 步骤 7 中的图像 1,1
    • Collect all the tools and prepare them for cleaning.
    • For water-based paint, rinse the tools in water. For oil-based paint, rinse the tools in paint thinner.
    • When rinsing, don't dip your tools in your paint thinner container directly. Instead, pour the paint thinner into another container that can be used for rinsing the tools.
结论
Follow these instructions so you can be the next person to learn how to paint.
另外一个人完成了本指南。
Chao Zheng
于09/20/20注册
177 声望
撰写一个指南
团队
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 18
总计 1,119
