Use a flat head screwdriver or a spudger to lift the connector locking clips.
Disconnect the connector by pulling it straight off.
Use long nose pliers to disconnect the first belt switch wire.
Use one hand to press down on the motor retainer clip bump. This should make it easy to unhook the clip from the motor cradle mount.
While maintaining the downward pressure, use your other hand to unhook the clip from the motor cradle mount.
结论
