跳转到主内容
How to Remove the Motor Whirlpool WED87HED Prereq
仅作为前提条件
本指南仅提供前提条件!本指南是另一个程序的一部分,不能单独使用。
  1. How to Remove the Motor Whirlpool WED87HED Prereq, Disconnect the motor: 步骤 1 中的图像 1,3 How to Remove the Motor Whirlpool WED87HED Prereq, Disconnect the motor: 步骤 1 中的图像 2,3 How to Remove the Motor Whirlpool WED87HED Prereq, Disconnect the motor: 步骤 1 中的图像 3,3
    • Use a flat head screwdriver to lift the connector locking clips.
    • Disconnect the connector by pulling it straight off.
    • Be sure to grip the connector and not the wires when disconnecting.
  2. How to Remove the Motor Whirlpool WED87HED Prereq, Disconnect the belt switch leads: 步骤 2 中的图像 1,3 How to Remove the Motor Whirlpool WED87HED Prereq, Disconnect the belt switch leads: 步骤 2 中的图像 2,3 How to Remove the Motor Whirlpool WED87HED Prereq, Disconnect the belt switch leads: 步骤 2 中的图像 3,3
    • Use long nose pliers to disconnect the blue belt switch wire with the metal head.
    • Be sure to grip the connector and not the wire when disconnecting.
    • The third photo will help on reassembly.
  3. How to Remove the Motor Whirlpool WED87HED Prereq: 步骤 3 中的图像 1,2 How to Remove the Motor Whirlpool WED87HED Prereq: 步骤 3 中的图像 2,2
    • Disconnect the blue belt switch lead with the white connector.
  4. How to Remove the Motor Whirlpool WED87HED Prereq, Remove the motor retaining clips: 步骤 4 中的图像 1,3 How to Remove the Motor Whirlpool WED87HED Prereq, Remove the motor retaining clips: 步骤 4 中的图像 2,3 How to Remove the Motor Whirlpool WED87HED Prereq, Remove the motor retaining clips: 步骤 4 中的图像 3,3
    • Use one hand to press down on the motor retainer clip bump. This should make it easy to unhook the clip from the motor cradle mount.
    • While maintaining the downward pressure, use your other hand to unhook the clip from the motor cradle mount.
  5. How to Remove the Motor Whirlpool WED87HED Prereq: 步骤 5 中的图像 1,1
    • Lift the motor retainer clip off the motor and remove it.
    • Repeat the last two steps for the other motor clip.
  6. How to Remove the Motor Whirlpool WED87HED Prereq, Remove the motor: 步骤 6 中的图像 1,2 How to Remove the Motor Whirlpool WED87HED Prereq, Remove the motor: 步骤 6 中的图像 2,2
    • Lift the motor out of the motor mount and remove it.
结论
Bill Gilbert
于06/30/22注册
38,516 声望
创作了261篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了23,758篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 24
