跳转到主内容
How to Remove the Front Panel in Your Whirlpool Refrigerator
你所需要的
  1. How to Remove the Front Panel in Your Whirlpool Refrigerator, Safety precautions: 步骤 1 中的图像 1,1
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
  2. How to Remove the Front Panel in Your Whirlpool Refrigerator, Open the doors: 步骤 2 中的图像 1,3 How to Remove the Front Panel in Your Whirlpool Refrigerator, Open the doors: 步骤 2 中的图像 2,3 How to Remove the Front Panel in Your Whirlpool Refrigerator, Open the doors: 步骤 2 中的图像 3,3
    • Depending on your repair, open one or both doors.
  3. How to Remove the Front Panel in Your Whirlpool Refrigerator, Unfasten the front panel: 步骤 3 中的图像 1,3 How to Remove the Front Panel in Your Whirlpool Refrigerator, Unfasten the front panel: 步骤 3 中的图像 2,3 How to Remove the Front Panel in Your Whirlpool Refrigerator, Unfasten the front panel: 步骤 3 中的图像 3,3
    • Remove the screw(s) securing the front panel.
  4. How to Remove the Front Panel in Your Whirlpool Refrigerator, Remove the front panel: 步骤 4 中的图像 1,3 How to Remove the Front Panel in Your Whirlpool Refrigerator, Remove the front panel: 步骤 4 中的图像 2,3 How to Remove the Front Panel in Your Whirlpool Refrigerator, Remove the front panel: 步骤 4 中的图像 3,3
    • Pull the front panel straight off the chassis and remove it.
    • You may have to slightly open the water filter door to remove the front panel completely.
结论
Repair didn’t go as planned? Ask our Answers community for help.
另外一个人完成了本指南。
nicO
于04/14/15注册
15,945 声望
创作了89篇指南
2指南评论
Woah, felicidades tío!
Cayó un whirlpool hace unos meses en mis manos y li resolví gracias a ti.
Ahora tengo otro whirlpool ARC7470 y no enfría, bien...motor ok pero termostato muerto.
Es el n⁰ de pieza: Whirlpool C00312889
Pero no se cambiarlo. Saque el panel de temperatura pero no doy con donde esta y menos como lo puedo cambiar. #HELP.
GRACIAS!🙂
Omar Marí - 回复
Hola, tengo un refri Whirlpool, pero al abrir la puerta se apaga el panel, y deja de funcionar
Dieris Mora - 回复
添加评论
浏览统计数据:
过去 24 小时: 7
过去 7 天: 36
过去 30 天: 142
总计 6,371
