简介
If your TI-NSpire calculator is experiencing operational issues, it may be necessary to remove the back plate to access the inner circuitry. This repair guide will demonstrate how to safely and efficiently remove the back plate without causing any damage to the wires or connectors.
Once removed, you will have access to the battery, display, and buttons, which is essential for other troubleshooting guides that require the replacement or repair of these components. You can find the model number of your TI-Nspire on the front logo or on the back of the device. Model Number: TI-Nspire CX.
你所需要的
Place the calculator screen facing down, with the back plate facing up.
To reassemble your device, carefully push the back plate back onto the calculator. Then replace the screws back into the back plate.
另外一个人完成了本指南。
