跳转到主内容
How to Remove scratches from a CD
你所需要的
  1. How to Remove scratches from a CD, How to Remove scratches from a CD: 步骤 1 中的图像 1,1
    • Identify any scratches.
    • Some scratches may be too deep to be removed. In this case, this method may not work.
  2. How to Remove scratches from a CD: 步骤 2 中的图像 1,2 How to Remove scratches from a CD: 步骤 2 中的图像 2,2
    • Take the CD to the sink.
    • Wash with lukewarm water to remove any dust or dirt.
  3. How to Remove scratches from a CD: 步骤 3 中的图像 1,1
    • Let the CD air dry, or dry with towel.
    • Use a non-linen towel or your CD will need to be washed again.
  4. How to Remove scratches from a CD: 步骤 4 中的图像 1,3 How to Remove scratches from a CD: 步骤 4 中的图像 2,3 How to Remove scratches from a CD: 步骤 4 中的图像 3,3
    • Take the toothpaste, and apply it to your index finger.
    • Rinse the toothpaste in lukewarm water and apply to the CD.
    • Rub toothpaste in a circular motion from the center to the outer edge.
    • Add multiple layers of toothpaste to cover all of the scratches.
    • Use a white toothpaste, not a gel. Gels containing little beads may cause more damage to the CD.
  5. How to Remove scratches from a CD: 步骤 5 中的图像 1,1
    • Let the CD sit for 2 to 3 minutes.
    Unless I’m missing something, If you’re using toothpaste to polish the scratches out of a CD, there’s no need to let it sit with the paste on it. It’s the circular motion moving the aggregate in the paste that is removing the scratches.
    Jimmy Hoffa - 回复
  6. How to Remove scratches from a CD: 步骤 6 中的图像 1,1
    • Rinse off the toothpaste with lukewarm water.
  7. How to Remove scratches from a CD: 步骤 7 中的图像 1,1
    • Let the CD air dry, or dry with a non-linen towel.
  8. How to Remove scratches from a CD: 步骤 8 中的图像 1,1
    • Inspect your disk.
    • If your disk still has scratches, repeat the process.
    • You could also try to burn the disk onto another disk if the disk is lagging.
结论
40等其他人完成本指南。
Nick Jones
于09/29/15注册
1,389 声望
撰写一个指南
团队
Cal Poly, Team 14-4, Green Fall 2015 Cal Poly, Team 14-4, Green Fall 2015 的会员
CPSU-GREEN-F15S14G4
5 名成员
创作了16篇指南
5条评论
thank youuuuuuuuu
aboabdo.2007 - 回复
Funziona anche con i DVD di film e videogiochi questo procedimento? Oppure è solo specifico per i CD?
Francesco Pepe - 回复
It did not work for me
Leisy Madrigal - 回复
Me Funciono muy bien, gracias!
Esteban Montero - 回复
添加评论
浏览统计数据:
过去 24 小时: 37
过去 7 天: 295
过去 30 天: 1,152
总计 56,894
