跳转到主内容
加入维修社区 - 创建账户
How to Remove scratches from a CD
你所需要的
    1. How to Remove scratches from a CD, How to Remove scratches from a CD: 步骤 1 中的图像 1,1
      • Identify any scratches.
      • Some scratches may be too deep to be removed. In this case, this method may not work.
      询问修复机器人
      添加评论
    2. How to Remove scratches from a CD: 步骤 2 中的图像 1,2 How to Remove scratches from a CD: 步骤 2 中的图像 2,2
      • Take the CD to the sink.
      • Wash with lukewarm water to remove any dust or dirt.
      询问修复机器人
      添加评论
    3. How to Remove scratches from a CD: 步骤 3 中的图像 1,1
      • Let the CD air dry, or dry with towel.
      • Use a non-linen towel or your CD will need to be washed again.
      添加评论
    4. How to Remove scratches from a CD: 步骤 4 中的图像 1,3 How to Remove scratches from a CD: 步骤 4 中的图像 2,3 How to Remove scratches from a CD: 步骤 4 中的图像 3,3
      • Take the toothpaste, and apply it to your index finger.
      • Rinse the toothpaste in lukewarm water and apply to the CD.
      • Rub toothpaste in a circular motion from the center to the outer edge.
      • Add multiple layers of toothpaste to cover all of the scratches.
      • Use a white toothpaste, not a gel. Gels containing little beads may cause more damage to the CD.
      询问修复机器人
      添加评论
    5. How to Remove scratches from a CD: 步骤 5 中的图像 1,1
      • Let the CD sit for 2 to 3 minutes.
      添加评论
    6. How to Remove scratches from a CD: 步骤 6 中的图像 1,1
      • Rinse off the toothpaste with lukewarm water.
      询问修复机器人
      添加评论
    7. How to Remove scratches from a CD: 步骤 7 中的图像 1,1
      • Let the CD air dry, or dry with a non-linen towel.
      询问修复机器人
      添加评论
    8. How to Remove scratches from a CD: 步骤 8 中的图像 1,1
      • Inspect your disk.
      • If your disk still has scratches, repeat the process.
      • You could also try to burn the disk onto another disk if the disk is lagging.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
53等其他人完成本指南。
Nick Jones
于09/29/15注册
1,701 声望
撰写一个指南
团队
Cal Poly, Team 14-4, Green Fall 2015 Cal Poly, Team 14-4, Green Fall 2015 的会员
CPSU-GREEN-F15S14G4
5 名成员
创作了35篇指南
5指南评论
Works great!
Paul Johnson - 回复 分享
thank youuuuuuuuu
aboabdo.2007 - 回复 分享
Funziona anche con i DVD di film e videogiochi questo procedimento? Oppure è solo specifico per i CD?
Francesco Pepe - 回复 分享
It did not work for me
Leisy Madrigal - 回复 分享
Me Funciono muy bien, gracias!
Esteban Montero - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 56
过去 7 天: 303
过去 30 天: 1,612
总计 98,629
