跳转到主内容
How to Remove and Replace Caulk in a Bathtub
你所需要的
  1. How to Remove and Replace Caulk in a Bathtub, Replacing Caulk in Bathtub: 步骤 1 中的图像 1,1
    • Remove current caulk from bathtub using a sharp tool such as a knife or utility tool. Test it first in a small area to not scrape the bathtub.
  2. How to Remove and Replace Caulk in a Bathtub: 步骤 2 中的图像 1,1
    • Clean the surface and mold from the area with a putty knife. Excess caulk can be removed with a combination of liquid caulk removal. Remove the rest of the residue with a knife.
  3. How to Remove and Replace Caulk in a Bathtub: 步骤 3 中的图像 1,1
    • Dry the area well to prevent mold from forming and it let it dry overnight before continuing the next step.
  4. How to Remove and Replace Caulk in a Bathtub: 步骤 4 中的图像 1,2 How to Remove and Replace Caulk in a Bathtub: 步骤 4 中的图像 2,2
    • Tape around the area that is going to be caulked. Place the tape 1/8 inch on either side of the seam that is going to be caulked. The tape keeps the caulk in a smooth line.
  5. How to Remove and Replace Caulk in a Bathtub: 步骤 5 中的图像 1,2 How to Remove and Replace Caulk in a Bathtub: 步骤 5 中的图像 2,2
    • Trim the opening of the caulk from the caulk gun to 1/8 an inch and use it a 45-degree angle and make sure it is the same size as the area between the tape.
  6. How to Remove and Replace Caulk in a Bathtub: 步骤 6 中的图像 1,2 How to Remove and Replace Caulk in a Bathtub: 步骤 6 中的图像 2,2
    • Load the caulk gun and use a steady pressure along the space between the tape as you move across it. An even pace is needed; if it’s too slow the caulk will pile up, and if it’s too fast it will break easily.
  7. How to Remove and Replace Caulk in a Bathtub: 步骤 7 中的图像 1,1
    • Smooth out the line of caulk with your finger.
  8. How to Remove and Replace Caulk in a Bathtub: 步骤 8 中的图像 1,2 How to Remove and Replace Caulk in a Bathtub: 步骤 8 中的图像 2,2
    • Remove tape and fix any blemishes.
结论
If you are how unhappy how the caulk turned out; don’t worry you can just do the following the steps again as there is no permanent damage done with caulking.
另外一个人完成了本指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 12
过去 30 天: 43
总计 3,590
