跳转到主内容
How to Remove and Clean the Kenmore 575-0 Float Switch
你所需要的
  1. How to Remove and Clean the Kenmore 575-0 Float Switch, How to Remove and Clean the Kenmore 575-0 Float Switch: 步骤 1 中的图像 1,3 How to Remove and Clean the Kenmore 575-0 Float Switch, How to Remove and Clean the Kenmore 575-0 Float Switch: 步骤 1 中的图像 2,3 How to Remove and Clean the Kenmore 575-0 Float Switch, How to Remove and Clean the Kenmore 575-0 Float Switch: 步骤 1 中的图像 3,3
    • To easily access the float assembly, open the dishwasher and carefully slide out the lower rack.
    • To prevent accidents, make sure the dishwasher is disconnected from both power and water sources.
  2. How to Remove and Clean the Kenmore 575-0 Float Switch: 步骤 2 中的图像 1,3 How to Remove and Clean the Kenmore 575-0 Float Switch: 步骤 2 中的图像 2,3 How to Remove and Clean the Kenmore 575-0 Float Switch: 步骤 2 中的图像 3,3
    • Use a Phillips #1 screwdriver to remove two 5 mm screws from the ends of the bottom cover of the dishwasher.
    • Remove the bottom cover.
  3. How to Remove and Clean the Kenmore 575-0 Float Switch: 步骤 3 中的图像 1,3 How to Remove and Clean the Kenmore 575-0 Float Switch: 步骤 3 中的图像 2,3 How to Remove and Clean the Kenmore 575-0 Float Switch: 步骤 3 中的图像 3,3
    • Loosen the single 5 mm screw at the base of the dishwasher that secures the float switch in place using a Phillips #1 screwdriver.
    • This will enable you to lift, remove, and clean the float located inside the dishwasher beneath the lower rack.
    • Ensure that the lever inside the float switch remains in its position and does not displace when you unscrew the float switch.
  4. How to Remove and Clean the Kenmore 575-0 Float Switch: 步骤 4 中的图像 1,3 How to Remove and Clean the Kenmore 575-0 Float Switch: 步骤 4 中的图像 2,3 How to Remove and Clean the Kenmore 575-0 Float Switch: 步骤 4 中的图像 3,3
    • Find the float assembly positioned near the front, underneath the lower rack.
    • Carefully press on top of the float assembly and then release to elevate the float.
    • Avoid excessive force when lifting, as it may result in damage to the float.
  5. How to Remove and Clean the Kenmore 575-0 Float Switch: 步骤 5 中的图像 1,1
    • Check the float for any debris or residue. If it's dirty, clean it thoroughly with warm, soapy water and a soft brush. Also, clean the area where the float was installed.
  6. How to Remove and Clean the Kenmore 575-0 Float Switch: 步骤 6 中的图像 1,3 How to Remove and Clean the Kenmore 575-0 Float Switch: 步骤 6 中的图像 2,3 How to Remove and Clean the Kenmore 575-0 Float Switch: 步骤 6 中的图像 3,3
    • Reconnect the float assembly to its initial position and fasten it securely. Verify that it moves smoothly and without obstruction.
    • Now that the float switch is clean, reinsert the lower rack.
    • Reassemble the base of the dishwasher.
    • Close the dishwasher and turn on the power and water.
结论
Anirudh Chaudhary
于09/13/23注册
133 声望
撰写一个指南
团队
York University, Team 1-8, O'Regan Fall 2023 York University, Team 1-8, O'Regan Fall 2023 的会员
YORK-O'REGAN-F23S1G8
1 名成员
创作了1篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 39
总计 323
