跳转到主内容
How to Remove a Stripped Screw
你所需要的
视频概述
  1. How to Remove a Stripped Screw, How to Remove a Stripped Screw: 步骤 1 中的图像 1,1
    • Your screw is stripped, and your screwdriver is no longer sufficient. Before busting out the heavy hitters, try the following:
    • Use different screwdrivers. First try slightly smaller or larger head sizes, then a flat head screwdriver, to see if you can get it to catch on some part of the stripped screw.
    • If the bit doesn't catch the screw instantly, do not continue. Otherwise, you run the risk of further stripping the screw.
    • If either of these techniques are fruitful, congrats! Your screw is free.
  2. How to Remove a Stripped Screw: 步骤 2 中的图像 1,3 How to Remove a Stripped Screw: 步骤 2 中的图像 2,3 How to Remove a Stripped Screw: 步骤 2 中的图像 3,3
    • A rubber band can give you the extra grip you need.
    • Stretch a rubber band over the stripped screw.
    • Insert a properly-sized screwdriver, and give it a turn.
  3. How to Remove a Stripped Screw: 步骤 3 中的图像 1,2 How to Remove a Stripped Screw: 步骤 3 中的图像 2,2
    在这个步骤中使用的工具:
    Screw Extracting Pliers
    $19.99
    购买
    • If the screw head is accessible, try a pair of screw extracting pliers. If you can get a good grip, turn the pliers and the screw should turn along with it!
    • Once the screw is loosened a bit, you can probably back it out the rest of the way using a screwdriver.
  4. How to Remove a Stripped Screw: 步骤 4 中的图像 1,3 How to Remove a Stripped Screw: 步骤 4 中的图像 2,3 How to Remove a Stripped Screw: 步骤 4 中的图像 3,3
    • Still stuck? Try adding a dab of superglue to the top of the screw.
    • Set your driver into the screw head, and allow the glue to dry.
    • Using a firm grip and downward pressure, give the driver a twist to remove the screw.
    • Don't forget to clean the remains of the glue from the tip of your driver.
  5. How to Remove a Stripped Screw: 步骤 5 中的图像 1,1
    • If you were unable to remove the screw with screwdrivers, pliers, a rubber band, or super glue, then a rotary tool should do the trick.
    • Attach a thin cutting disk to your rotary tool. Before you cut anything, make sure the disk is secured well.
    • Make sure you wear protective goggles anytime you use a rotary tool to prevent injuries from flying debris and sparks.
  6. How to Remove a Stripped Screw: 步骤 6 中的图像 1,2 How to Remove a Stripped Screw: 步骤 6 中的图像 2,2
    • In this step, you will use the rotary tool to make a thin cut in the stripped screw that enables you to use a flathead screwdriver to remove the screw.
    • We recommend using a low power setting (we used 2 out of 6) to prevent damaging the rest of the device or the screw.
    • You want the cut to be deep enough that you can fit a flathead screwdriver into it, but thin enough that the screwdriver has something to grip.
    • Make a single thin cut into the head of the stripped screw.
  7. How to Remove a Stripped Screw: 步骤 7 中的图像 1,1
    • Use a flathead screwdriver to remove the screw from the device.
    • The size of the driver will depend on the size of the screw, but use the largest size that will fit in your cut.
    • If you cannot fit a screwdriver into the cut, use the rotary tool to make the cut larger. Make only small cuts; if you cut off too much of the screw, a screwdriver will not catch and you will not be able to twist the screw.
    • Wear eye protection and give your device a few good blasts of compressed air before reassembling it. The rotary tool can scatter loose metal shavings around the device, creating the potential for an electrical short if not blown clear.
结论
Check out the video in the intro for some additional tips on dealing with stripped screws. Always use a high-quality screwdriver. Low-quality screwdriver material will cause damage to screws.
246等其他人完成本指南。
Jake Devincenzi
于04/18/11注册
117,301 声望
创作了57篇指南
62条评论
I usually use the soldering iron, resting on the screw head dilation of the materials or any glue on the thread, but if the damage the screw head is large only with the idea of ​​same rotary tool.
Cleyton - 回复
"To reassemble your device, follow these instructions in reverse order."
Yeah, that makes perfect sense... If you put the saw in reverse it glues all the buts of iron back onto the screw :-)
But other than that, this could be useful in some situations. Be careful,of the iron filings on your electronics!
koesper - 回复
Haha, good catch! We've fixed the conclusion. Apologies to all who tried so very hard to follow these instructions in reverse.
Jeff Suovanen -
There's always the ultimate tool if it won't go out, the drill.
Of course you'll have to make new threads if you drill out a screw. However, as a "weapon of last resort", the drill always works.
Branko Dodig - 回复
Thank you for this guide. The Vampliers, however, completely removed the head of my T6 screw. There are two of them holding the display to the top case of my 15'' Macbook Pro. I am on one of the last steps in the Top Case replacement guide.
Can I use a drill if my screw has virtually no head?
Thanks!
A Mac User - 回复
添加评论
浏览统计数据:
过去 24 小时: 336
过去 7 天: 2,332
过去 30 天: 12,250
总计 1,751,533
