跳转到主内容
How to Remove a Label From a Glass Jar
你所需要的
  1. How to Remove a Label From a Glass Jar, How to Remove a Label From a Glass Jar: 步骤 1 中的图像 1,1
    • Boil enough water to fill both glass jars.
    • Pour the boiling water into the smaller jar using a tea kettle.
    • The hot water will heat up the glass and melt the adhesive from the inside.
  2. How to Remove a Label From a Glass Jar: 步骤 2 中的图像 1,2 How to Remove a Label From a Glass Jar: 步骤 2 中的图像 2,2
    • Place the lid onto the jar and tighten.
    • This step is optional if the larger container in Step 3 has a lid.
  3. How to Remove a Label From a Glass Jar: 步骤 3 中的图像 1,2 How to Remove a Label From a Glass Jar: 步骤 3 中的图像 2,2
    • Place the jar into a larger glass container.
  4. How to Remove a Label From a Glass Jar: 步骤 4 中的图像 1,1
    • Pour hot water into the larger jar until the water level is above the label.
  5. How to Remove a Label From a Glass Jar: 步骤 5 中的图像 1,1
    • Add a few drops of dish soap into the larger jar.
    • This helps to clean up residue from the label.
  6. How to Remove a Label From a Glass Jar: 步骤 6 中的图像 1,2 How to Remove a Label From a Glass Jar: 步骤 6 中的图像 2,2
    • Place the lid on the larger container and tighten.
    • This prevents heat from leaving the container.
    • Let the container sit for 10 to 15 minutes or until completely cooled.
  7. How to Remove a Label From a Glass Jar: 步骤 7 中的图像 1,2 How to Remove a Label From a Glass Jar: 步骤 7 中的图像 2,2
    • Remove the smaller jar from the larger container.
    • Pour the water out of the jar.
    • Peel the label off of the jar.
    • For containers with loose labels, the label will fall off or be able to be slipped off.
    • Wipe off excess residue with a cloth or paper towel.
终点
3等其他人完成本指南。
Ridhwan Hasnat
于01/17/22注册
235 声望
撰写一个指南
团队
1指南评论
Génial ! Je n'y avais jamais pensé. Merci beaucoup !
Josette Léost - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 18
总计 829
