跳转到主内容
How to Remove a Filament Clog on a Cubify Cube 3D Printer (3rd Generation)
你所需要的
  1. How to Remove a Filament Clog on a Cubify Cube 3D Printer (3rd Generation), How to Remove a Filament Clog on a Cubify Cube 3D Printer (3rd Generation): 步骤 1 中的图像 1,2 How to Remove a Filament Clog on a Cubify Cube 3D Printer (3rd Generation), How to Remove a Filament Clog on a Cubify Cube 3D Printer (3rd Generation): 步骤 1 中的图像 2,2
    • On the top of the printer, turn the injector counter-clockwise and pull the tab.
  2. How to Remove a Filament Clog on a Cubify Cube 3D Printer (3rd Generation): 步骤 2 中的图像 1,3 How to Remove a Filament Clog on a Cubify Cube 3D Printer (3rd Generation): 步骤 2 中的图像 2,3 How to Remove a Filament Clog on a Cubify Cube 3D Printer (3rd Generation): 步骤 2 中的图像 3,3
    • Insert your fingers in the center of the filament cartridge and slowly pull it away from the printer.
  3. How to Remove a Filament Clog on a Cubify Cube 3D Printer (3rd Generation): 步骤 3 中的图像 1,1
    • Place the cartridge face up and pry off the lid of the cartridge.
  4. How to Remove a Filament Clog on a Cubify Cube 3D Printer (3rd Generation): 步骤 4 中的图像 1,2 How to Remove a Filament Clog on a Cubify Cube 3D Printer (3rd Generation): 步骤 4 中的图像 2,2
    • Gently flip the cartridge on its front and remove the two 2mm Hex screws using a Hex key.
  5. How to Remove a Filament Clog on a Cubify Cube 3D Printer (3rd Generation): 步骤 5 中的图像 1,1
    • Flip the cartridge face up and remove the gearbox and extractor tube.
  6. How to Remove a Filament Clog on a Cubify Cube 3D Printer (3rd Generation): 步骤 6 中的图像 1,3 How to Remove a Filament Clog on a Cubify Cube 3D Printer (3rd Generation): 步骤 6 中的图像 2,3 How to Remove a Filament Clog on a Cubify Cube 3D Printer (3rd Generation): 步骤 6 中的图像 3,3
    • Place your thumb on the front of the injector head and your middle finger on the needle.
    • Firmly pull the needle towards your thumb until the injector head cases cracks and pulls apart the case.
  7. How to Remove a Filament Clog on a Cubify Cube 3D Printer (3rd Generation): 步骤 7 中的图像 1,2 How to Remove a Filament Clog on a Cubify Cube 3D Printer (3rd Generation): 步骤 7 中的图像 2,2
    • Heat the needle using a lighter, making sure that the flame does not touch the needle.
    • Using needle-nose pliers, pull the needle from the tube.
    • Do not touch the needle as it may still be hot.
  8. How to Remove a Filament Clog on a Cubify Cube 3D Printer (3rd Generation): 步骤 8 中的图像 1,1
    • Insert a paper clip and turn until the clog is removed.
结论
Hector Vazquez
于10/23/20注册
157 声望
撰写一个指南
团队
CSU Los Angeles, Team S12-G11, Harris Fall 2020 CSU Los Angeles, Team S12-G11, Harris Fall 2020 的会员
CSULA-HARRIS-F20S12G11
1 名成员
创作了2篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 8
总计 541
