跳转到主内容
How to Remove a Burn Mark on a Wooden Floor
你所需要的
  1. How to Remove a Burn Mark on a Wooden Floor, How to Remove a Burn Mark on a Wooden Floor: 步骤 1 中的图像 1,1
    • Use dish soap with warm water to scrub off any additional food or oil stains before beginning the process.
    • In this case, we are starting with a clean board.
  2. How to Remove a Burn Mark on a Wooden Floor: 步骤 2 中的图像 1,1
    • Use a pocket knife to carefully grind off the burn mark.
    • Grind parallel to the wood grain.
  3. How to Remove a Burn Mark on a Wooden Floor: 步骤 3 中的图像 1,1
    • Sand the area using 150 grit sandpaper until smooth, diminishing the crevice.
  4. How to Remove a Burn Mark on a Wooden Floor: 步骤 4 中的图像 1,1
    • Wipe off the area, ridding any sanded particles.
  5. How to Remove a Burn Mark on a Wooden Floor: 步骤 5 中的图像 1,1
    • Use a brush to apply a small amount of wood polish on the sanded area.
    • Make sure to use wood polish consistent to rest of the floor.
  6. How to Remove a Burn Mark on a Wooden Floor: 步骤 6 中的图像 1,1
    • Let the polish dry, applying another layer if necessary.
终点
另外一个人完成了本指南。
Ian Kim
于11/13/24注册
163 声望
撰写一个指南
团队
UC Davis, Team 3-7, Vidal-Chiesa Fall 2024 UC Davis, Team 3-7, Vidal-Chiesa Fall 2024 的会员
UCD-VIDAL-CHIESA-F24S3G7
3 名成员
创作了1篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 34
总计 328
