跳转到主内容
How to Remove a Broken and Embedded Screw
你所需要的
  1. How to Remove a Broken and Embedded Screw, How to Remove a Broken and Embedded Screw: 步骤 1 中的图像 1,1
    • Use an angle grinder to grind the tip of the broken screw until its surface is smooth and even.
  2. How to Remove a Broken and Embedded Screw: 步骤 2 中的图像 1,2 How to Remove a Broken and Embedded Screw: 步骤 2 中的图像 2,2
    • Place a center punch in the middle of the tip of the screw.
    • Use a hammer to hit the center punch to make a dent in the center of the embedded screw.
  3. How to Remove a Broken and Embedded Screw: 步骤 3 中的图像 1,3 How to Remove a Broken and Embedded Screw: 步骤 3 中的图像 2,3 How to Remove a Broken and Embedded Screw: 步骤 3 中的图像 3,3
    • Place a center drill bit in the dent made in the previous step and start drilling until it expands enough to fit the standard drill bit inside it.
    • Always keep the drill bit at a 90 degree angle to the surface of the screw since tilting it can bend and break its tip.
  4. How to Remove a Broken and Embedded Screw: 步骤 4 中的图像 1,3 How to Remove a Broken and Embedded Screw: 步骤 4 中的图像 2,3 How to Remove a Broken and Embedded Screw: 步骤 4 中的图像 3,3
    • Make a hole in the tip of the screw by drilling with a standard drill bit.
    • Keep drilling until the hole reaches near the end of the screw.
  5. How to Remove a Broken and Embedded Screw: 步骤 5 中的图像 1,2 How to Remove a Broken and Embedded Screw: 步骤 5 中的图像 2,2
    • Insert a screw extractor in the hole and then hammer it inside, making sure it is tight.
  6. How to Remove a Broken and Embedded Screw: 步骤 6 中的图像 1,3 How to Remove a Broken and Embedded Screw: 步骤 6 中的图像 2,3 How to Remove a Broken and Embedded Screw: 步骤 6 中的图像 3,3
    • Using a wrench, unscrew the extractor.
    • The screw will come along with it, freeing the hole.
  7. How to Remove a Broken and Embedded Screw: 步骤 7 中的图像 1,2 How to Remove a Broken and Embedded Screw: 步骤 7 中的图像 2,2
    • Screw the new screw inside the freed hole.
终点
3等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 11
过去 7 天: 104
过去 30 天: 472
总计 7,888
