跳转到主内容
加入维修社区 - 创建账户
How to Remove a Blood Stain from Satin
你所需要的
  1. How to Remove a Blood Stain from Satin, How to Remove a Blood Stain from Satin: 步骤 1 中的图像 1,2 How to Remove a Blood Stain from Satin, How to Remove a Blood Stain from Satin: 步骤 1 中的图像 2,2
    • Dip the stained fabric in bowl of cold water.
    • Massage the stain while submerged for about 20 seconds to ensure that it is fully saturated.
  2. How to Remove a Blood Stain from Satin: 步骤 2 中的图像 1,1
    • Pour laundry detergent or dish soap into bowl.
    • Amount poured should equate to approximately 1/2 cup (120ml). Larger stains may require higher quantities.
  3. How to Remove a Blood Stain from Satin: 步骤 3 中的图像 1,2 How to Remove a Blood Stain from Satin: 步骤 3 中的图像 2,2
    • Wet a clean, dry cloth or sponge in the bowl.
  4. How to Remove a Blood Stain from Satin: 步骤 4 中的图像 1,2 How to Remove a Blood Stain from Satin: 步骤 4 中的图像 2,2
    • Dab the stain gently by repeatedly pressing the wet cloth or sponge against it.
    • Rubbing the stain may further spread it and/or embed it deeper in the fabric.
  5. How to Remove a Blood Stain from Satin: 步骤 5 中的图像 1,2 How to Remove a Blood Stain from Satin: 步骤 5 中的图像 2,2
    • Rinse the stain with cold water.
    • Inspect to determine whether further cleaning is required.
  6. How to Remove a Blood Stain from Satin: 步骤 6 中的图像 1,1
    • Add a few drops of vinegar or hydrogen peroxide to the initial solution if the stain persists.
    • Repeat steps 3 and 4.
    • The combination of these chemicals creates peracetic acid. Do not mix hydrogen peroxide and vinegar.
  7. How to Remove a Blood Stain from Satin: 步骤 7 中的图像 1,1
    • Rinse the garment in a bowl of clean water.
结论
Repeat as needed until the stain is gone.
Malak Elsayed Elghobashy
于02/06/25注册
145 声望
撰写一个指南
团队
York University, Team 1-1, Morris Winter 2025 York University, Team 1-1, Morris Winter 2025 的会员
YORK-MORRIS-W25S1G1
5 名成员
创作了2篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 14
过去 7 天: 52
过去 30 天: 191
总计 1,186
