跳转到主内容
How to Remove Wax From Clothing
你所需要的
  1. How to Remove Wax From Clothing, Removing Dried Wax: 步骤 1 中的图像 1,1
    • Set up the ironing board.
    • Plug in the iron and turn it on.
    • Your iron may need some time to heat up, especially if it is an older model.
  2. How to Remove Wax From Clothing: 步骤 2 中的图像 1,1
    • Place your piece of clothing onto the ironing board.
  3. How to Remove Wax From Clothing: 步骤 3 中的图像 1,2 How to Remove Wax From Clothing: 步骤 3 中的图像 2,2
    • Take your brown paper bag and fold it over the affected area, being sure to cover both sides of the waxy clothing.
  4. How to Remove Wax From Clothing: 步骤 4 中的图像 1,1
    • Press the iron on top of the brown paper bag.
    • Move the iron around as if you are ironing wrinkles out.
    • Be careful not to burn your fingers.
  5. How to Remove Wax From Clothing: 步骤 5 中的图像 1,2 How to Remove Wax From Clothing: 步骤 5 中的图像 2,2
    • Lift up the brown paper bag once it looks like the oil has saturated the bag.
    • Repeat steps 3-5 with new bags, until the remainder of the wax is soaked up.
  6. How to Remove Wax From Clothing: 步骤 6 中的图像 1,1
    • Feel free to wash your item now that the wax is removed, just as you normally would.
结论
To finish getting wax out it is not a bad idea to wash your item, if possible, in a washing machine for a clothing item or use carpet wash for the carpet.
Molly Green
于04/23/20注册
133 声望
撰写一个指南
团队
UW Tacoma, Team S1-G7, Cardinal Spring 2020 UW Tacoma, Team S1-G7, Cardinal Spring 2020 的会员
UWT-CARDINAL-S20S1G7
1 名成员
创作了2篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 40
总计 631
