跳转到主内容
加入维修社区 - 创建账户
How to Remove Stickers From a Car
你所需要的
  1. How to Remove Stickers From a Car, How to Remove Stickers From a Car: 步骤 1 中的图像 1,1
    • First of all, find the area where the sticker is. In my case, it is on the car body near the fuel tank.
    询问修复机器人
    添加评论
  2. How to Remove Stickers From a Car: 步骤 2 中的图像 1,2 How to Remove Stickers From a Car: 步骤 2 中的图像 2,2
    • Spray the area with some soap water or with cleaning sprays. Goo gone work really well for this and might allow you to skip the blow dryer in the next step.
    询问修复机器人
    添加评论
  3. How to Remove Stickers From a Car: 步骤 3 中的图像 1,1
    在这个步骤中使用的工具:
    Microfiber Cleaning Cloths
    $3.99
    • Next, wipe the area thoroughly with a microfiber cleaning cloth. Skip this step if you're using Goo Gone.
    询问修复机器人
    添加评论
  4. How to Remove Stickers From a Car: 步骤 4 中的图像 1,2 How to Remove Stickers From a Car: 步骤 4 中的图像 2,2
    • Turn on the hairdryer and put it in its hot setting.
    • Start heating the sticker from a few inches away. Try to heat the sticker from the center outward.
    • This will soften the adhesive under the sticker and make the following steps much easier.
    • Using Goo Gone might allow you to skip this step, but for stubborn stickers, the hair dryer + Goo Gone will be most effective.
    询问修复机器人
    添加评论
  5. How to Remove Stickers From a Car: 步骤 5 中的图像 1,3 How to Remove Stickers From a Car: 步骤 5 中的图像 2,3 How to Remove Stickers From a Car: 步骤 5 中的图像 3,3
    在这个步骤中使用的工具:
    Plastic Cards
    $2.99
    • Use a plastic card and try to scrape the sticker from the edges.
    • A plastic card can help you remove your unwanted stickers without damaging the paint.
    • If it doesn't work, try to repeat step 4 and then try again.
    • If you are working on a glass surface, use a razor blade instead of a plastic card! It may seem too much for the glass, but the glass is hard enough to use a razor blade on.
    • Be careful when using a razor blade!
    询问修复机器人
    添加评论
  6. How to Remove Stickers From a Car: 步骤 6 中的图像 1,2 How to Remove Stickers From a Car: 步骤 6 中的图像 2,2
    • Finally, if there is any residue, heat the residue with the hairdryer and scrape it off with a plastic card or razor blade (depending on where the sticker is). Using Goo Gone makes removing any residue easy.
    • After removing all stickers and residue, use some detailing spray or cleaning spray to clean the area again and you are all set!
    询问修复机器人
    添加评论
结论
After these steps, you should have a clean surface without any residues!
取消:我没有完成这个指南。
Xuanfang Gao
于09/15/21注册
141 声望
撰写一个指南
团队
York University, Team E-7, Melo-Thaiss Fall 2021 York University, Team E-7, Melo-Thaiss Fall 2021 的会员
YORK-MELO-THAISS-F21SEG7
1 名成员
创作了2篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 13
过去 30 天: 70
总计 1,972
