跳转到主内容
加入维修社区 - 创建账户
How to Remove Rust on Car Body
你所需要的
  1. How to Remove Rust on Car Body, How to Remove Rust on Car Body: 步骤 1 中的图像 1,2 How to Remove Rust on Car Body, How to Remove Rust on Car Body: 步骤 1 中的图像 2,2
    • Spray down the rust with a spray bottle mixed with water and dish soap.
    • Wipe the mixture with a microfiber cloth.
    询问修复机器人
    添加评论
  2. How to Remove Rust on Car Body: 步骤 2 中的图像 1,3 How to Remove Rust on Car Body: 步骤 2 中的图像 2,3 How to Remove Rust on Car Body: 步骤 2 中的图像 3,3
    • Pour a small amount of rubbing alcohol onto a microfiber cloth.
    • Clean the rusted area with the cloth to remove any contaminants.
    询问修复机器人
    添加评论
  3. How to Remove Rust on Car Body: 步骤 3 中的图像 1,3 How to Remove Rust on Car Body: 步骤 3 中的图像 2,3 How to Remove Rust on Car Body: 步骤 3 中的图像 3,3
    • Rub the rusted area with 80-grit sandpaper until you start seeing the bare metal.
    询问修复机器人
    添加评论
  4. How to Remove Rust on Car Body: 步骤 4 中的图像 1,2 How to Remove Rust on Car Body: 步骤 4 中的图像 2,2
    • Rub the rusted area with 220-grit sandpaper until all of the rust is removed.
    • Dampen a cloth with soapy water and wipe down the sanded area.
    询问修复机器人
    添加评论
  5. How to Remove Rust on Car Body: 步骤 5 中的图像 1,2 How to Remove Rust on Car Body: 步骤 5 中的图像 2,2
    • This step is to prepare your spot for spray painting.
    • Add some paper around the areas you do not want paint on. Make sure you go a little past where you are going to spray paint to blend the paint into the surrounding area.
    询问修复机器人
    添加评论
  6. How to Remove Rust on Car Body: 步骤 6 中的图像 1,3 How to Remove Rust on Car Body: 步骤 6 中的图像 2,3 How to Remove Rust on Car Body: 步骤 6 中的图像 3,3
    • Spray three even coats of primer, waiting at least five minutes between each coat.
    • Let the third coat sit for 15 minutes.
    询问修复机器人
    添加评论
  7. How to Remove Rust on Car Body: 步骤 7 中的图像 1,3 How to Remove Rust on Car Body: 步骤 7 中的图像 2,3 How to Remove Rust on Car Body: 步骤 7 中的图像 3,3
    • Spray three even coats of paint on top of the primer, waiting five minutes between each coat.
    • You can either use a color similar to your car or you can get the actual color of you car by looking for the car's color code.
    • After the final coat, wait 24 hours before removing the surrounding paper.
    添加评论
终点
取消:我没有完成这个指南。
3等其他人完成本指南。
团队
CSU Los Angeles, Team 10-20, Briggs Fall 2022 CSU Los Angeles, Team 10-20, Briggs Fall 2022 的会员
CSULA-BRIGGS-F22S10G20
1 名成员
创作了1篇指南
1指南评论
Good guide, also recommending ChrisFix's video relating to this: https://www.youtube.com/watch?v=n4vusY2-...
Fixing Person - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 16
过去 30 天: 105
总计 4,554
