跳转到主内容
How to Remove Makeup Stain from Shirt
你所需要的
  1. How to Remove Makeup Stain from Shirt, How to Remove Makeup Stain from Shirt: 步骤 1 中的图像 1,1
    • Place a white napkin or rag under the shirt to avoid making a mess or colour transfer into the garment.
  2. How to Remove Makeup Stain from Shirt: 步骤 2 中的图像 1,2 How to Remove Makeup Stain from Shirt: 步骤 2 中的图像 2,2
    • Pour micellar water over the stain
    • Micellar water can be replaced by any kind of water-based makeup remover.
    • Do not use an oil-based makeup remover as it will permanently damage the shirt.
  3. How to Remove Makeup Stain from Shirt: 步骤 3 中的图像 1,2 How to Remove Makeup Stain from Shirt: 步骤 3 中的图像 2,2
    • Pat the stain dry with the napkin/rag from Step 1.
    • Do not use Kleenex tissues as they will fall apart and make a mess by sticking to the fabric.
  4. How to Remove Makeup Stain from Shirt: 步骤 4 中的图像 1,1
    • Wash the shirt in cold water with the detergent of your choice.
  5. How to Remove Makeup Stain from Shirt: 步骤 5 中的图像 1,1
    • Pour detergent over the stain. Pour baking soda or powder over the soap.
    • The recommended measurement is 1/4 of a teaspoon of baking soda/powder but you may use more if the stain is larger.
  6. How to Remove Makeup Stain from Shirt: 步骤 6 中的图像 1,1
    • Scrub the paste into the shirt with a toothbrush.
  7. How to Remove Makeup Stain from Shirt: 步骤 7 中的图像 1,1
    • Let rest for 15 minutes.
  8. How to Remove Makeup Stain from Shirt: 步骤 8 中的图像 1,1
    • Wash the shirt in cold water followed by lukewarm water.
  9. How to Remove Makeup Stain from Shirt: 步骤 9 中的图像 1,1
    • Let the shirt air dry and iron it if necessary.
结论
Let the shirt air dry and iron as needed.
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 15
总计 380
