简介
If your Vicks Mini Cool Mist Ultrasonic humidifier (VUL520WC) or any humidifier that you own isn’t producing mist, it is likely because of the hard water build up.
Through long time use, humidifiers start to build up hard water, especially if they are not cleaned and kept maintained regularly. This can damage the humidifier and ultimately prevent it from working.
Even if your humidifier is working with the hard water build up, it is still important to ensure that it is removed because a dirty humidifier can spread bacteria and other harmful chemicals into the air.
Use this guide to learn how to remove the hard water in order to have the humidifier producing mist normally again.
For detailed instructions on how to remove hard water build up for a warm mist humidifier, follow this guide instead.
你所需要的
Unplug the humidifier from the wall.
2等其他人完成本指南。
