跳转到主内容
How to Remove Dinner Plate Scratches
你所需要的
  1. How to Remove Dinner Plate Scratches, How to Remove Dinner Plate Scratches: 步骤 1 中的图像 1,1
    • Obtain a product called "Bar Keeper's Friend".
    • This product can be found at most grocery stores in the cleaning aisle. (It is available at Walmart)
  2. How to Remove Dinner Plate Scratches: 步骤 2 中的图像 1,1
    • Go to a sink so that you have access to running water.
    • Rinse off your dish so that the plate is moist.
  3. How to Remove Dinner Plate Scratches: 步骤 3 中的图像 1,1
    • Shake some of the "Bar Cleaner's Friend" powder onto the back of the plate to make sure that it does not damage the coloring.
    • Wet the sponge and wipe the plate to see if the product is damaging to your plate.
    • If it is, then stop usage immediately and rinse your plate to reduce damage.
    • If the product is not damaging, then continue use on the top of the plate.
    • Do not consume "Bar Cleaner's Friend" directly.
  4. How to Remove Dinner Plate Scratches: 步骤 4 中的图像 1,2 How to Remove Dinner Plate Scratches: 步骤 4 中的图像 2,2
    • Once you have flipped the plate over and sprinkled the plate with an thin and even layer of "Bar Keeper's Friend", scrub the plate with a sponge until the scratches are less visible.
  5. How to Remove Dinner Plate Scratches: 步骤 5 中的图像 1,1
    • When the powder and water are combined, a paste will form, as shown.
  6. How to Remove Dinner Plate Scratches: 步骤 6 中的图像 1,1
    • Once you have wiped the plate to your satisfaction (until most or all of the scratches have disappeared), squeeze out your sponge and rinse your plate and hands.
  7. How to Remove Dinner Plate Scratches: 步骤 7 中的图像 1,2 How to Remove Dinner Plate Scratches: 步骤 7 中的图像 2,2
    • Now, grab a paper towel and dry your plate by wiping.
    • When you have dried the plate completely, your plate is done and ready for use.
结论
Now you have a plate that looks good as new! To maintain the appearance of your dishware, simply use the same process described in this guide when scratches appear again.
4等其他人完成本指南。
Julia Trenkle
于04/09/15注册
256 声望
撰写一个指南
团队
Cal Poly, Team 30-3, Green Spring 2015 Cal Poly, Team 30-3, Green Spring 2015 的会员
CPSU-GREEN-S15S30G3
4 名成员
创作了10篇指南
1指南评论
I can’t get Bartender’s friend, but it inspired me to try a ceramic stove top cleaner. It worked like a charm. I was going to throw those dishes away. I have had them for 25 years. Now they will last at least another 15…
Tracee Meyn - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 24
总计 5,663
