跳转到主内容
How to Remove Calcium Buildup from a Shower Head
你所需要的
  1. How to Remove Calcium Buildup from a Shower Head, How to Remove Calcium Buildup from a Shower Head: 步骤 1 中的图像 1,2 How to Remove Calcium Buildup from a Shower Head, How to Remove Calcium Buildup from a Shower Head: 步骤 1 中的图像 2,2
    • Using an adjustable wrench, loosen the bolt that attaches the shower head to the wall spout by turning the wrench counterclockwise.
    • You may be able to loosen the shower head by hand.
    • Handle carefully because the shower head may be heavy.
  2. How to Remove Calcium Buildup from a Shower Head: 步骤 2 中的图像 1,1
    • Use your hands to finish unscrewing the bolt.
    • Remove the shower head from the wall spout.
  3. How to Remove Calcium Buildup from a Shower Head: 步骤 3 中的图像 1,3 How to Remove Calcium Buildup from a Shower Head: 步骤 3 中的图像 2,3 How to Remove Calcium Buildup from a Shower Head: 步骤 3 中的图像 3,3
    • Pour one cup of water into the plastic bag.
    • Completing this step over a sink may help to avoid spilling the water.
  4. How to Remove Calcium Buildup from a Shower Head: 步骤 4 中的图像 1,3 How to Remove Calcium Buildup from a Shower Head: 步骤 4 中的图像 2,3 How to Remove Calcium Buildup from a Shower Head: 步骤 4 中的图像 3,3
    • Pour one cup of distilled vinegar into the plastic bag.
    • Completing this step over a sink may help to avoid spilling the solution.
    • If using the vinegar solution provided in steps 3 and 4 fails to provide adequate results, you may want to repeat the steps using CLR (Calcium, Lime, and Rust) solution instead.
  5. How to Remove Calcium Buildup from a Shower Head: 步骤 5 中的图像 1,2 How to Remove Calcium Buildup from a Shower Head: 步骤 5 中的图像 2,2
    • Place the shower head face down into the plastic bag of vinegar solution.
    • Let the shower head sit for one hour before removing it from the plastic bag of vinegar solution.
  6. How to Remove Calcium Buildup from a Shower Head: 步骤 6 中的图像 1,1
    • After one hour, remove the shower head from the plastic bag of vinegar solution.
    • Use a metal sponge to scrub in a circular motion to remove the treated calcium on the shower head.
    • Excessive scrubbing could damage the finish.
  7. How to Remove Calcium Buildup from a Shower Head: 步骤 7 中的图像 1,2 How to Remove Calcium Buildup from a Shower Head: 步骤 7 中的图像 2,2
    • Place the shower head under running water to remove any extra calcium left behind.
    • If calcium is still present, repeat steps 5 through 7 as needed.
  8. How to Remove Calcium Buildup from a Shower Head: 步骤 8 中的图像 1,2 How to Remove Calcium Buildup from a Shower Head: 步骤 8 中的图像 2,2
    • Clamp the adjustable wrench onto the bolt of the shower head.
    • Turn the adjustable wrench clockwise to tighten the shower head back onto the water spout.
终点
3等其他人完成本指南。
Jacob Abrego
于02/23/16注册
150 声望
撰写一个指南
团队
Texas Tech, Team 26-6, Rauch Spring 2016 Texas Tech, Team 26-6, Rauch Spring 2016 的会员
TTU-RAUCH-S16S26G6
3 名成员
创作了4篇指南
一条评论
How to remove rust stain (from iron) from bathroom tiles?
waihong yeung - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 19
过去 30 天: 66
总计 9,232
