跳转到主内容
How to Remove Acrylic Paint from Artist Canvas
你所需要的
  1. How to Remove Acrylic Paint from Artist Canvas, How to Remove Acrylic Paint from Artist Canvas: 步骤 1 中的图像 1,2 How to Remove Acrylic Paint from Artist Canvas, How to Remove Acrylic Paint from Artist Canvas: 步骤 1 中的图像 2,2
    • Place the canvas with dried paint on a hard surface (i.e. desk, table, counter top, or floor).
  2. How to Remove Acrylic Paint from Artist Canvas: 步骤 2 中的图像 1,1
    • Pour rubbing alcohol onto the towel until it feels damp.
    • A cloth rag or towel is the preferred tool to apply the isopropyl alcohol. Use paper towels if you don't have a cloth rag.
    • Use cotton swabs or a small paintbrush for a precise application.
  3. How to Remove Acrylic Paint from Artist Canvas: 步骤 3 中的图像 1,1
    • Place the towel on top of the dried paint.
    • Allow the damp rag to rest on the dried paint.
    • Isopropyl alcohol will remove all the acrylic paint it touches. Be careful to keep it away from paint that you want to save.
  4. How to Remove Acrylic Paint from Artist Canvas: 步骤 4 中的图像 1,3 How to Remove Acrylic Paint from Artist Canvas: 步骤 4 中的图像 2,3 How to Remove Acrylic Paint from Artist Canvas: 步骤 4 中的图像 3,3
    • Gently the rag back and forth for about 30 seconds.
    • Check your progress. You will see the paint starting to lift from the canvas.
    • Do not scrub or push down on the canvas while applying the alcohol; this may tear the canvas.
  5. How to Remove Acrylic Paint from Artist Canvas: 步骤 5 中的图像 1,1
    • Allow the canvas to air dry completely.
    • Allow at least 2-3 minutes.
  6. How to Remove Acrylic Paint from Artist Canvas: 步骤 6 中的图像 1,3 How to Remove Acrylic Paint from Artist Canvas: 步骤 6 中的图像 2,3 How to Remove Acrylic Paint from Artist Canvas: 步骤 6 中的图像 3,3
    • Use cotton swabs (or a small paintbrush) for fine detail work.
    • Use a cloth rag or paper towel to pick up and remove the paint completely.
    • Repeat steps 2-6 until the paint is removed.
结论
Allow your cleaned canvas to dry completely before adding new paint.
4等其他人完成本指南。
2条评论
DID NOT WORKKK!!! do not try does not work for a whole canvas or acrylic paint it will just make your house smell like alcohol
Olive Guttormsen - 回复
I used acrylic on canvas to paint a portrait. When finished, I decided to change the color of the eyes, Using a small, old brush, I gently applied alcohol & blotted off the original color. I came off after repeating a few times. This technique saved an otherwise good painting.I don't think I'd have the patience to do a large area.
Carole - 回复
添加评论
浏览统计数据:
过去 24 小时: 26
过去 7 天: 257
过去 30 天: 1,090
总计 22,727
