跳转到主内容
How to Reinsert a Wooden Chair Side Stretcher
你所需要的
  1. How to Reinsert a Wooden Chair Side Stretcher, How to Reinsert a Wooden Chair Side Stretcher: 步骤 1 中的图像 1,2 How to Reinsert a Wooden Chair Side Stretcher, How to Reinsert a Wooden Chair Side Stretcher: 步骤 1 中的图像 2,2
    • Use the sandpaper to rough up the empty dowel holes on the side stretcher and the chairs legs.
  2. How to Reinsert a Wooden Chair Side Stretcher: 步骤 2 中的图像 1,2 How to Reinsert a Wooden Chair Side Stretcher: 步骤 2 中的图像 2,2
    • Check if the new dowel fits through the stretcher hole and the leg hole.
  3. How to Reinsert a Wooden Chair Side Stretcher: 步骤 3 中的图像 1,3 How to Reinsert a Wooden Chair Side Stretcher: 步骤 3 中的图像 2,3 How to Reinsert a Wooden Chair Side Stretcher: 步骤 3 中的图像 3,3
    • Using the disposable stirrer and bowl, mix a 2:1 ratio of sawdust and wood glue.
    • The final consistency should be paste-like.
  4. How to Reinsert a Wooden Chair Side Stretcher: 步骤 4 中的图像 1,3 How to Reinsert a Wooden Chair Side Stretcher: 步骤 4 中的图像 2,3 How to Reinsert a Wooden Chair Side Stretcher: 步骤 4 中的图像 3,3
    • With the stirrer, fill in the leg hole of the broken dowel with the paste.
  5. How to Reinsert a Wooden Chair Side Stretcher: 步骤 5 中的图像 1,2 How to Reinsert a Wooden Chair Side Stretcher: 步骤 5 中的图像 2,2
    • Apply a glob of wood glue to the other leg's hole.
    • Use the stirrer to spread the glue around the hole.
  6. How to Reinsert a Wooden Chair Side Stretcher: 步骤 6 中的图像 1,2 How to Reinsert a Wooden Chair Side Stretcher: 步骤 6 中的图像 2,2
    • Insert the intact stretcher dowel into the leg hole with wood glue.
  7. How to Reinsert a Wooden Chair Side Stretcher: 步骤 7 中的图像 1,2 How to Reinsert a Wooden Chair Side Stretcher: 步骤 7 中的图像 2,2
    • Align the empty stretcher hole to the the leg hole filled with paste.
    • Insert the dowel and firmly push it in till it's fully submerged into the stretcher hole.
    • Insertion of the dowel will push out some of the wood paste.
  8. How to Reinsert a Wooden Chair Side Stretcher: 步骤 8 中的图像 1,2 How to Reinsert a Wooden Chair Side Stretcher: 步骤 8 中的图像 2,2
    • Put the legs holding the stretcher between the bar clamp's jaws.
    • Screw in the handle to clamp together the legs until it is secure.
    • Putting a cloth or barrier between the clamp and the leg can prevent possible damage to the wood's surface.
  9. How to Reinsert a Wooden Chair Side Stretcher: 步骤 9 中的图像 1,1
    • Remove any wood glue or paste residue on the legs and stretcher with a damp paper towel.
  10. How to Reinsert a Wooden Chair Side Stretcher: 步骤 10 中的图像 1,1
    • Leave the chair and bar clamp in place for 24 hours while the wood glue and paste cures.
    • After waiting, screw out the clamp's handle to remove it from the chair.
结论
Your chair should now resemble how it was before, with the side stretcher back in place. Happy fixing!
另外一个人完成了本指南。
Shaelyn
于02/01/24注册
205 声望
撰写一个指南
团队
UC Davis, Team 3-6, Andersen Winter 2024 UC Davis, Team 3-6, Andersen Winter 2024 的会员
UCD-ANDERSEN-W24S3G6
2 名成员
创作了1篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 18
总计 744
