跳转到主内容
How to Reinforce the Cross Stretcher of a Wooden Chair
你所需要的
  1. How to Reinforce the Cross Stretcher of a Wooden Chair, How to Reinforce the Cross Stretcher of a Wooden Chair: 步骤 1 中的图像 1,3 How to Reinforce the Cross Stretcher of a Wooden Chair, How to Reinforce the Cross Stretcher of a Wooden Chair: 步骤 1 中的图像 2,3 How to Reinforce the Cross Stretcher of a Wooden Chair, How to Reinforce the Cross Stretcher of a Wooden Chair: 步骤 1 中的图像 3,3
    • Flip the chair upside down.
    • Make sure you identify the loose cross stretcher and that you are comfortable working in that position.
  2. How to Reinforce the Cross Stretcher of a Wooden Chair: 步骤 2 中的图像 1,3 How to Reinforce the Cross Stretcher of a Wooden Chair: 步骤 2 中的图像 2,3 How to Reinforce the Cross Stretcher of a Wooden Chair: 步骤 2 中的图像 3,3
    • Verify that your screw is able to get through the cross diagonally and fit in the upright leg of the chair.
    • Place a tape on the end of the cross bar.
    • Mark the drill spot.
    • Make sure the length of the screw is long enough to penetrate the chair leg at least 0.5 centimeters or 0.2 inches in depth.
  3. How to Reinforce the Cross Stretcher of a Wooden Chair: 步骤 3 中的图像 1,3 How to Reinforce the Cross Stretcher of a Wooden Chair: 步骤 3 中的图像 2,3 How to Reinforce the Cross Stretcher of a Wooden Chair: 步骤 3 中的图像 3,3
    • Measure the desired depth of the vertical drilling.
    • Tape the drill bit according to the depth measurement.
    • The desired depth varies but is typically around 10 mm deep.
  4. How to Reinforce the Cross Stretcher of a Wooden Chair: 步骤 4 中的图像 1,3 How to Reinforce the Cross Stretcher of a Wooden Chair: 步骤 4 中的图像 2,3 How to Reinforce the Cross Stretcher of a Wooden Chair: 步骤 4 中的图像 3,3
    • Drill the chair vertically from the surface of the marked spot on the tape.
    • Stop drilling once the tape on the drill bit reaches the surface.
    • Keep your hand away from the rotating drill bit. Hold the chair steady to secure the drilling spot.
  5. How to Reinforce the Cross Stretcher of a Wooden Chair: 步骤 5 中的图像 1,2 How to Reinforce the Cross Stretcher of a Wooden Chair: 步骤 5 中的图像 2,2
    • Remove the tape from the drill bit.
    • Mark the drill bit with tape again to match the screw's length.
  6. How to Reinforce the Cross Stretcher of a Wooden Chair: 步骤 6 中的图像 1,3 How to Reinforce the Cross Stretcher of a Wooden Chair: 步骤 6 中的图像 2,3 How to Reinforce the Cross Stretcher of a Wooden Chair: 步骤 6 中的图像 3,3
    • Align the drill bit diagonally and into the previously drilled hole, so the new intended drill path crosses both the cross-stretcher and the chair leg.
    • Drill diagonally into the cross-stretcher and chair leg, and stop when the tape mark on the drill bit is reached.
    • Pull out the drill while the drill is still on to avoid breaking the drill bit.
  7. How to Reinforce the Cross Stretcher of a Wooden Chair: 步骤 7 中的图像 1,3 How to Reinforce the Cross Stretcher of a Wooden Chair: 步骤 7 中的图像 2,3 How to Reinforce the Cross Stretcher of a Wooden Chair: 步骤 7 中的图像 3,3
    • Place the screw into the diagonal hole.
    • Using either a screw driver or drill with a Phillips screwdriver, place the screw in diagonally.
    • Remove the tape.
结论
Alex Fung
于04/19/23注册
145 声望
撰写一个指南
团队
UCD-MORRIS-S23S1G2 UCD-MORRIS-S23S1G2 的会员
Community
3 名成员
创作了1篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 10
过去 30 天: 30
总计 321
