跳转到主内容
How to Reinforce a Hammock
你所需要的
  1. How to Reinforce a Hammock, How to Reinforce a Hammock: 步骤 1 中的图像 1,2 How to Reinforce a Hammock, How to Reinforce a Hammock: 步骤 1 中的图像 2,2
    • Remove and discard any damaged rope from your hammock.
  2. How to Reinforce a Hammock: 步骤 2 中的图像 1,2 How to Reinforce a Hammock: 步骤 2 中的图像 2,2
    • Use a power drill and a 3/8 size drill bit to drill small hole in one side of the tree.
  3. How to Reinforce a Hammock: 步骤 3 中的图像 1,1
    • Insert the screw eye screw into the hole and begin screwing it in to the tree until it is secured fully into the tree.
    • A screwdriver or flathead may be needed at this point to make sure the screw eye is all the way in the tree.
  4. How to Reinforce a Hammock: 步骤 4 中的图像 1,2 How to Reinforce a Hammock: 步骤 4 中的图像 2,2
    • Attach the metal clasp to the rings attached to the end of the hammock.
  5. How to Reinforce a Hammock: 步骤 5 中的图像 1,2 How to Reinforce a Hammock: 步骤 5 中的图像 2,2
    • Once your screw eye is inserted fully into the tree and your metal clasps are connected to the ends of the hammock you can attach the metal clasp to the the screw eye.
  6. How to Reinforce a Hammock: 步骤 6 中的图像 1,1
    • After attaching the hammock to the tree, repeat steps 1-5 on the other side of the hammock to the other side.
    • You will want to make sure that the second tree is at least 6ft-7ft away from the first tree.
终点
另外一个人完成了本指南。
Leanne Works
于07/05/23注册
160 声望
撰写一个指南
团队
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 23
总计 560
