跳转到主内容
How to Refinish a Scratched Wood Table
你所需要的
  1. How to Refinish a Scratched Wood Table, How to Refinish a Scratched Wood Table: 步骤 1 中的图像 1,3 How to Refinish a Scratched Wood Table, How to Refinish a Scratched Wood Table: 步骤 1 中的图像 2,3 How to Refinish a Scratched Wood Table, How to Refinish a Scratched Wood Table: 步骤 1 中的图像 3,3
    • Flip your table over on the tabletop or on the side if applicable.
    • Get your hex keys or screwdriver.
    • Using your tool to unscrew all of the legs on the table.
  2. How to Refinish a Scratched Wood Table: 步骤 2 中的图像 1,2 How to Refinish a Scratched Wood Table: 步骤 2 中的图像 2,2
    • Using a damp cloth, wipe down the tabletop and all of the legs.
  3. How to Refinish a Scratched Wood Table: 步骤 3 中的图像 1,3 How to Refinish a Scratched Wood Table: 步骤 3 中的图像 2,3 How to Refinish a Scratched Wood Table: 步骤 3 中的图像 3,3
    • Get the 220 grit sandpaper and cut a smaller piece.
    • Sand the tabletop until all scratches are leveled with the wood.
    • Sand all of the legs.
    • You may use a sander if you do not want to sand the table by hand.
  4. How to Refinish a Scratched Wood Table: 步骤 4 中的图像 1,1
    • Paint all of the legs and let them dry.
    • Be sure to mix your paint to ensure it hasn't separated before applying.
  5. How to Refinish a Scratched Wood Table: 步骤 5 中的图像 1,1
    • Paint the tabletop and let it dry.
    • If using wood paint, coat the tabletop more than once.
  6. How to Refinish a Scratched Wood Table: 步骤 6 中的图像 1,3 How to Refinish a Scratched Wood Table: 步骤 6 中的图像 2,3 How to Refinish a Scratched Wood Table: 步骤 6 中的图像 3,3
    • Line up the legs with the screw holes.
    • Hand tighten the screws and then use the hex keys or screwdriver to completely tighten.
    • Attach all legs and flip the table onto its legs.
终点
另外一个人完成了本指南。
Gurvir Boparai
于01/10/22注册
133 声望
撰写一个指南
团队
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 16
过去 30 天: 58
总计 1,748
