跳转到主内容
How to Recaulk a Toilet
你所需要的
  1. How to Recaulk a Toilet, Toilet Caulk: 步骤 1 中的图像 1,3 How to Recaulk a Toilet, Toilet Caulk: 步骤 1 中的图像 2,3 How to Recaulk a Toilet, Toilet Caulk: 步骤 1 中的图像 3,3
    • Wet a paper towel with warm water and wipe away any old caulk residue
    • Once all the residue is removed, wipe away the remaining water with a new dry paper towel until the area is completely dry.
  2. How to Recaulk a Toilet: 步骤 2 中的图像 1,2 How to Recaulk a Toilet: 步骤 2 中的图像 2,2
    • Using scissors, clip the tip of your caulk tube to it's intended length, which is indicated by a line on the tip of your caulk tube
  3. How to Recaulk a Toilet: 步骤 3 中的图像 1,2 How to Recaulk a Toilet: 步骤 3 中的图像 2,2
    • Using gentle pressure and grip, caulk around the entirety of the toilet rim
  4. How to Recaulk a Toilet: 步骤 4 中的图像 1,3 How to Recaulk a Toilet: 步骤 4 中的图像 2,3 How to Recaulk a Toilet: 步骤 4 中的图像 3,3
    • When you're done caulking the entirety of the rim, make soapy water by mixing liquid dish soap and warm water. Then apply the soapy water gently to the rim of the toilet.
    • Using a paper towel, wipe around the rim of to ensure that the caulk is neatly placed around the toilets rim.
  5. How to Recaulk a Toilet: 步骤 5 中的图像 1,3 How to Recaulk a Toilet: 步骤 5 中的图像 2,3 How to Recaulk a Toilet: 步骤 5 中的图像 3,3
    • When you feel the caulk is well laid, wipe up the remaining soapy water with a dry paper towel
结论
After twenty-four hours your toilet will be recalked like new and ready to be used.
另外一个人完成了本指南。
DaNaria
于10/23/23注册
148 声望
撰写一个指南
团队
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 29
总计 446
