跳转到主内容
How to Rebuild a Briggs and Stratton Quantum Engine Carburetor
你所需要的
  1. How to Rebuild a Briggs and Stratton Quantum Engine Carburetor, Remove the Air Filter Cover: 步骤 1 中的图像 1,3 How to Rebuild a Briggs and Stratton Quantum Engine Carburetor, Remove the Air Filter Cover: 步骤 1 中的图像 2,3 How to Rebuild a Briggs and Stratton Quantum Engine Carburetor, Remove the Air Filter Cover: 步骤 1 中的图像 3,3
    • The air filter and its cover are located to the right of the yellow warning label under the throttle cable.
    • Remove the single screw attaching the cover and filter using a 5/16'' socket.
    • Pull straight outward until the filter assembly is detached.
    • The screw is a flat head as well as a 5/16'' socket.
  2. How to Rebuild a Briggs and Stratton Quantum Engine Carburetor, Remove the throttle Cable: 步骤 2 中的图像 1,1
    • The throttle cable will be located above the air filter assembly.
    • Use a flathead screwdriver to remove the throttle cable.
    • If your engine is not equipped with a throttle, skip this step.
  3. How to Rebuild a Briggs and Stratton Quantum Engine Carburetor: 步骤 3 中的图像 1,2 How to Rebuild a Briggs and Stratton Quantum Engine Carburetor: 步骤 3 中的图像 2,2
    • Remove the backplate of the air filter assembly to access the carburetor.
    • Using a 5/16" socket, remove the three screws inside of the assembly.
  4. How to Rebuild a Briggs and Stratton Quantum Engine Carburetor: 步骤 4 中的图像 1,3 How to Rebuild a Briggs and Stratton Quantum Engine Carburetor: 步骤 4 中的图像 2,3 How to Rebuild a Briggs and Stratton Quantum Engine Carburetor: 步骤 4 中的图像 3,3
    • Remove the fuel line spring clamp with pliers.
    • Remove the fuel line from the carburetor by pulling directly outward.
    • Crimp the line with locking pliers. Do this before removing the fuel line to mitigate fuel spillage.
    • Drain the fuel line into a container and dispose of it properly.
  5. How to Rebuild a Briggs and Stratton Quantum Engine Carburetor: 步骤 5 中的图像 1,2 How to Rebuild a Briggs and Stratton Quantum Engine Carburetor: 步骤 5 中的图像 2,2
    • To remove the carburetor, use a 3/8" socket with an extension and ratchet to remove the two screws attached to the engine block.
    • Turn the carb 90 degrees, and pull off of the Z bend in the carb linkage.
  6. How to Rebuild a Briggs and Stratton Quantum Engine Carburetor: 步骤 6 中的图像 1,3 How to Rebuild a Briggs and Stratton Quantum Engine Carburetor: 步骤 6 中的图像 2,3 How to Rebuild a Briggs and Stratton Quantum Engine Carburetor: 步骤 6 中的图像 3,3
    • Remove the carburetor bowl screw with a 1/2" socket and ratchet.
    • Empty fuel from the carburetor bowl into a container for disposal.
  7. How to Rebuild a Briggs and Stratton Quantum Engine Carburetor: 步骤 7 中的图像 1,3 How to Rebuild a Briggs and Stratton Quantum Engine Carburetor: 步骤 7 中的图像 2,3 How to Rebuild a Briggs and Stratton Quantum Engine Carburetor: 步骤 7 中的图像 3,3
    • Spray the interior of the carburetor with carb cleaner.
    • Remove the float pin.
    • This will allow the float and needle to be removed as one piece.
    • This is not a full carburetor cleaning. This is just a rinse-off.
  8. How to Rebuild a Briggs and Stratton Quantum Engine Carburetor: 步骤 8 中的图像 1,3 How to Rebuild a Briggs and Stratton Quantum Engine Carburetor: 步骤 8 中的图像 2,3 How to Rebuild a Briggs and Stratton Quantum Engine Carburetor: 步骤 8 中的图像 3,3
    • Spray out the three major spots in the following order: the main adjustment hole, the inlet needle hole, and the main jet.
    • If the carb cleaner does not pass through any component, use a small piece of wire to poke through the passage.
    • If using a needle to clear passages, spray the passages with carb cleaner after clearing.
  9. How to Rebuild a Briggs and Stratton Quantum Engine Carburetor: 步骤 9 中的图像 1,1
    • After all parts are clean, lay them out to prepare for reassembly.
结论
另外一个人完成了本指南。
Matthew Dunham
于03/24/21注册
166 声望
撰写一个指南
团队
UMass Dartmouth, Team S6-G8, Riel Spring 2021 UMass Dartmouth, Team S6-G8, Riel Spring 2021 的会员
UMASSD-RIEL-S21S6G8
1 名成员
创作了1篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 11
过去 30 天: 116
总计 8,439
