跳转到主内容
How to Reattach the Head of a Mailbox to the Base
你所需要的
  1. How to Reattach the Head of a Mailbox to the Base, How to Reattach the Head of a Mailbox to the Base: 步骤 1 中的图像 1,2 How to Reattach the Head of a Mailbox to the Base, How to Reattach the Head of a Mailbox to the Base: 步骤 1 中的图像 2,2
    • Inspect the head of the mailbox to see where the detachment is located.
  2. How to Reattach the Head of a Mailbox to the Base: 步骤 2 中的图像 1,2 How to Reattach the Head of a Mailbox to the Base: 步骤 2 中的图像 2,2
    • Gather all materials needed.
    • Adhesive can be included depending on the tight fit you desire.
  3. How to Reattach the Head of a Mailbox to the Base: 步骤 3 中的图像 1,3 How to Reattach the Head of a Mailbox to the Base: 步骤 3 中的图像 2,3 How to Reattach the Head of a Mailbox to the Base: 步骤 3 中的图像 3,3
    • Measure out the wood plank to match the length and width of the mailbox head.
  4. How to Reattach the Head of a Mailbox to the Base: 步骤 4 中的图像 1,3 How to Reattach the Head of a Mailbox to the Base: 步骤 4 中的图像 2,3 How to Reattach the Head of a Mailbox to the Base: 步骤 4 中的图像 3,3
    • Use a hammer or mallet to nail this wood plank to the bottom of mailbox head. Use at least four nails for this task.
    • Use gloves, if deemed necessary!
  5. How to Reattach the Head of a Mailbox to the Base: 步骤 5 中的图像 1,2 How to Reattach the Head of a Mailbox to the Base: 步骤 5 中的图像 2,2
    • Screw the sides down for a stronger fit using at least four screws.
  6. How to Reattach the Head of a Mailbox to the Base: 步骤 6 中的图像 1,1
    • Align the mailbox head back on the post.
  7. How to Reattach the Head of a Mailbox to the Base: 步骤 7 中的图像 1,2 How to Reattach the Head of a Mailbox to the Base: 步骤 7 中的图像 2,2
    • Hammer down the head to the post of the mailbox with at least three more nails.
    • Add adhesive if necessary for a sturdier attachment.
    • Since your hands are inside the mailbox, it may be best to use gloves for this task.
终点
Terrell Cobbins
于03/21/23注册
145 声望
撰写一个指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 37
总计 952
