跳转到主内容
How to Reattach the Cap on a 4 mm iFixit Precision Bit Driver
你所需要的
  1. How to Reattach the Cap on a 4 mm iFixit Precision Bit Driver, Cut a piece of floss: 步骤 1 中的图像 1,2 How to Reattach the Cap on a 4 mm iFixit Precision Bit Driver, Cut a piece of floss: 步骤 1 中的图像 2,2
    • Cut an approximately six-inch piece of waxed dental floss.
  2. How to Reattach the Cap on a 4 mm iFixit Precision Bit Driver, Wrap the floss around the post: 步骤 2 中的图像 1,3 How to Reattach the Cap on a 4 mm iFixit Precision Bit Driver, Wrap the floss around the post: 步骤 2 中的图像 2,3 How to Reattach the Cap on a 4 mm iFixit Precision Bit Driver, Wrap the floss around the post: 步骤 2 中的图像 3,3
    • The blue cap is secured to the bit driver by a threaded post that screws into the bit driver's upper body.
    • The threaded post can't be screwed into the upper body by twisting the cap because the cap spins freely around the post. Instead, you'll need to hold the post still so the upper body can be screwed on.
    • Hold one end of the floss against the side of the cap.
    • Wrap the middle of the floss twice around the widest part of the post (below the rubber o-ring).
    • Don't tie the floss into a knot as this will prevent you from removing the floss after the upper body has been screwed on to the threaded post.
  3. How to Reattach the Cap on a 4 mm iFixit Precision Bit Driver, Tighten the floss: 步骤 3 中的图像 1,2 How to Reattach the Cap on a 4 mm iFixit Precision Bit Driver, Tighten the floss: 步骤 3 中的图像 2,2
    • Pull the two ends of the floss tight to create a secure hold on the post.
  4. How to Reattach the Cap on a 4 mm iFixit Precision Bit Driver, Arrange and hold the ends of the floss: 步骤 4 中的图像 1,3 How to Reattach the Cap on a 4 mm iFixit Precision Bit Driver, Arrange and hold the ends of the floss: 步骤 4 中的图像 2,3 How to Reattach the Cap on a 4 mm iFixit Precision Bit Driver, Arrange and hold the ends of the floss: 步骤 4 中的图像 3,3
    • Arrange the ends of the floss so that they hang down over the edge of the cap on the opposite side that they crossed on the post.
    • Press the ends of the floss against the side of the cap to prevent the post from spinning.
  5. How to Reattach the Cap on a 4 mm iFixit Precision Bit Driver, Optional threadlocker information: 步骤 5 中的图像 1,1
    • You can optionally apply a threadlocker (such as Loctite Threadlocker Blue 242) to secure the threaded post to the upper body.
    • Put on your protective gloves and safety glasses while applying the threadlocker.
    • Clean the threaded post and the upper body's screw hole with a lint-free cloth.
    • Apply one to two drops of threadlocker to the threaded post.
    • Make sure you don't get threadlocker on any other part of the cap. Doing so may prevent the cap from spinning. You only need to apply enough for an even spread on the threaded post.
    • After screwing the upper body on to the threaded post, wait for the recommended cure time before using the bit driver.
  6. How to Reattach the Cap on a 4 mm iFixit Precision Bit Driver, Screw the upper body on to the post: 步骤 6 中的图像 1,2 How to Reattach the Cap on a 4 mm iFixit Precision Bit Driver, Screw the upper body on to the post: 步骤 6 中的图像 2,2
    • Insert the threaded post into the upper body's screw hole.
  7. How to Reattach the Cap on a 4 mm iFixit Precision Bit Driver: 步骤 7 中的图像 1,3 How to Reattach the Cap on a 4 mm iFixit Precision Bit Driver: 步骤 7 中的图像 2,3 How to Reattach the Cap on a 4 mm iFixit Precision Bit Driver: 步骤 7 中的图像 3,3
    • Screw the upper body of the bit driver clockwise on to the threaded post until it is finger-tight.
    • The ends of the floss will rotate clockwise when the upper body is almost fully screwed on. Continue to screw the upper body for about half a turn after this occurs to screw it on completely.
  8. How to Reattach the Cap on a 4 mm iFixit Precision Bit Driver, Remove the floss: 步骤 8 中的图像 1,3 How to Reattach the Cap on a 4 mm iFixit Precision Bit Driver, Remove the floss: 步骤 8 中的图像 2,3 How to Reattach the Cap on a 4 mm iFixit Precision Bit Driver, Remove the floss: 步骤 8 中的图像 3,3
    • Pull and rotate one end of the floss around the post twice in the opposite direction that it was wrapped.
  9. How to Reattach the Cap on a 4 mm iFixit Precision Bit Driver: 步骤 9 中的图像 1,1
    • Pull and remove the floss from the bit driver.
    • If the floss is difficult to remove, try pulling on the other end. You can hold the gap between the cap and the bit driver at eye level to see if the floss is still looped around the post.
结论
Repair didn’t go as planned? Ask our iFixit Precision Bit Driver Answers community for help.
18等其他人完成本指南。
Kyle Smith
于02/01/21注册
49,280 声望
创作了123篇指南
8指南评论
Great guide.
Duck - 回复
Thanks for this information. I was worried about this but now I am Happy.
Saddaf Khan - 回复
Well that’s interesting. My blue cap popped off the screw. I had to use superglue… :-\
Ryan Coleman - 回复
Ok this is an epic repairability and culture standard that is demonstrated with this article - posting instructions on how to repair your own products! I wish this kind of attitude would spread in all tech industries.
I run a small tech startup myself, and this article just inspired me to do the same for the products we develop
Ignas Kaz - 回复
Great this was the only thing talkative annoyed my about this set. Now I can fixit brilliant.. had a few do it in the past ones at my work and ones I use on my youtube channel.. but would not use or recommend any other tools.
Neil - 回复
添加评论
浏览统计数据:
过去 24 小时: 14
过去 7 天: 102
过去 30 天: 575
总计 23,210
