跳转到主内容
How to Reattach an Umbrella Strap
你所需要的
  1. How to Reattach an Umbrella Strap, How to Reattach an Umbrella Strap: 步骤 1 中的图像 1,3 How to Reattach an Umbrella Strap, How to Reattach an Umbrella Strap: 步骤 1 中的图像 2,3 How to Reattach an Umbrella Strap, How to Reattach an Umbrella Strap: 步骤 1 中的图像 3,3
    • CAUTION: Seam rippers have a sharp blade; always use with caution and be aware of surroundings.
    • Notice how the strap is attached to the rest of the umbrella. The orientation matters.
    • Expose the broken stitching holding the umbrella and strap together.
    • Detach the two pieces by using the seam ripper to pull out the threads and rip through them.
  2. How to Reattach an Umbrella Strap: 步骤 2 中的图像 1,1
    • Remove any excess thread left on the umbrella strap.
  3. How to Reattach an Umbrella Strap: 步骤 3 中的图像 1,2 How to Reattach an Umbrella Strap: 步骤 3 中的图像 2,2
    • Lay the umbrella strap flat, then mark the original sewing line with a piece of fabric chalk.
  4. How to Reattach an Umbrella Strap: 步骤 4 中的图像 1,2 How to Reattach an Umbrella Strap: 步骤 4 中的图像 2,2
    • Repeat Step 3 for the body of the umbrella.
  5. How to Reattach an Umbrella Strap: 步骤 5 中的图像 1,3 How to Reattach an Umbrella Strap: 步骤 5 中的图像 2,3 How to Reattach an Umbrella Strap: 步骤 5 中的图像 3,3
    • CAUTION: Pins have a sharp point. Use with caution!
    • Align both pieces of the fabric together in the original orientation using the marked white lines as guidance.
    • Take one pin and push it down through both layers of the fabric above the original stitching line.
    • When the pin is halfway through the fabric, push it back up through the two layers.
    • Repeat this process for the second pin below the original stitching line.
  6. How to Reattach an Umbrella Strap: 步骤 6 中的图像 1,2 How to Reattach an Umbrella Strap: 步骤 6 中的图像 2,2
    • Cut 12 inches of black thread with a pair of scissors.
  7. How to Reattach an Umbrella Strap: 步骤 7 中的图像 1,3 How to Reattach an Umbrella Strap: 步骤 7 中的图像 2,3 How to Reattach an Umbrella Strap: 步骤 7 中的图像 3,3
    • Hold the needle with the eye facing upwards, then carefully push the black thread into the needle's eye.
    • Tip: Moisten end of the thread to ease threading process and prevent fraying.
    • Taking the other end of the thread that did not go through the eye of the needle, make a small loop, and run that end of the thread through it.
    • Pull the thread to tighten and secure the knot.
  8. How to Reattach an Umbrella Strap: 步骤 8 中的图像 1,2 How to Reattach an Umbrella Strap: 步骤 8 中的图像 2,2
    • KEY TIP: The holes of the previous stitching should still be visible. Follow these holes for the new stitches. If they are not visible, individual stitches are around an 1/8 inch in length each.
    • Begin the stitch at the second hole in from the right.
    • Poke the needle up through the fabric from the underside.
    • Pull the needle through until the knot hits the fabric; you will feel resistance.
  9. How to Reattach an Umbrella Strap: 步骤 9 中的图像 1,3 How to Reattach an Umbrella Strap: 步骤 9 中的图像 2,3 How to Reattach an Umbrella Strap: 步骤 9 中的图像 3,3
    • Poke the needle down through the first hole (which is to the right of the second hole).
    • While the needle is halfway through the first hole, angle it up, then poke it through the third hole.
    • Flip the fabric over to check that the needle is piercing the fabric, as shown in the third photo.
  10. How to Reattach an Umbrella Strap: 步骤 10 中的图像 1,2 How to Reattach an Umbrella Strap: 步骤 10 中的图像 2,2
    • Pull the needle and thread through the fabric completely until the thread is tight against the fabric.
    • Make sure the fabric is not scrunched.
  11. How to Reattach an Umbrella Strap: 步骤 11 中的图像 1,2 How to Reattach an Umbrella Strap: 步骤 11 中的图像 2,2
    • Repeat the same methods in Steps 9 and 10 until you have pulled the needle up through the last hole.
    • Remove the pins.
  12. How to Reattach an Umbrella Strap: 步骤 12 中的图像 1,3 How to Reattach an Umbrella Strap: 步骤 12 中的图像 2,3 How to Reattach an Umbrella Strap: 步骤 12 中的图像 3,3
    • To complete the line of stitches, poke the needle through the hole to the right.
    • Pull the needle straight down instead of bringing it back up through the fabric.
    • Pull the thread until it is tight.
  13. How to Reattach an Umbrella Strap: 步骤 13 中的图像 1,3 How to Reattach an Umbrella Strap: 步骤 13 中的图像 2,3 How to Reattach an Umbrella Strap: 步骤 13 中的图像 3,3
    • Flip the fabric over to see the underside.
    • Create a loop with the thread.
    • Run the needle through the open loop.
    • Pull the thread tight to create a knot.
  14. How to Reattach an Umbrella Strap: 步骤 14 中的图像 1,1
    • Trim off any excess thread on the fixed umbrella strap and the body.
  15. How to Reattach an Umbrella Strap: 步骤 15 中的图像 1,1
    • Pull both ends of the umbrella fabric to test the strength of stitching. The repair is now complete!
结论
Now your umbrella is ready to be used!
Emily-Mae McConihe
于02/19/25注册
241 声望
撰写一个指南
团队
UC Davis, Team 2-9, Andersen Winter 2025 UC Davis, Team 2-9, Andersen Winter 2025 的会员
UCD-ANDERSEN-W25S2G9
2 名成员
创作了1篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 8
过去 30 天: 33
总计 305
