跳转到主内容
加入维修社区 - 创建账户
How to Reattach a North Face Backpack Bungee Cord
你所需要的
    1. How to Reattach a North Face Backpack Bungee Cord, How to Reattach a North Face Backpack Bungee Cord: 步骤 1 中的图像 1,3 How to Reattach a North Face Backpack Bungee Cord, How to Reattach a North Face Backpack Bungee Cord: 步骤 1 中的图像 2,3 How to Reattach a North Face Backpack Bungee Cord, How to Reattach a North Face Backpack Bungee Cord: 步骤 1 中的图像 3,3
      • Find the North Face Backpack's broken Cord.
      • Use scissors to cut about an inch (24.5 mm) off the end of the broken bungee cord.
      • If there is more than an inch of fraying or damage to the cord, cut all of the frayed cord off. This makes it easier to pull the cord through the slit made in the next step.
      • Twist the end to make it easier to insert the cord back through the hole.
      询问修复机器人
      添加评论
    2. How to Reattach a North Face Backpack Bungee Cord: 步骤 2 中的图像 1,3 How to Reattach a North Face Backpack Bungee Cord: 步骤 2 中的图像 2,3 How to Reattach a North Face Backpack Bungee Cord: 步骤 2 中的图像 3,3
      • Find the grommet where the cord should be reattached on the outside layer of the backpack.
      • Unzip the front pocket of the backpack and fold it back.
      询问修复机器人
      添加评论
    3. How to Reattach a North Face Backpack Bungee Cord: 步骤 3 中的图像 1,3 How to Reattach a North Face Backpack Bungee Cord: 步骤 3 中的图像 2,3 How to Reattach a North Face Backpack Bungee Cord: 步骤 3 中的图像 3,3
      • Use scissors to cut a straight line in the inner fabric layer behind the grommet to allow the cord to pass through.
      • Try to keep the cut around 2–3 inches long—just wide enough to pull the cord through and access the grommet, while limiting the amount of sewing required in later steps.
      • Scissors can cut you, so be careful!
      询问修复机器人
      添加评论
    4. How to Reattach a North Face Backpack Bungee Cord: 步骤 4 中的图像 1,3 How to Reattach a North Face Backpack Bungee Cord: 步骤 4 中的图像 2,3 How to Reattach a North Face Backpack Bungee Cord: 步骤 4 中的图像 3,3
      • Put the cord through the hole on the outside.
      • Pull the cord through the inside pocket.
      询问修复机器人
      添加评论
    5. How to Reattach a North Face Backpack Bungee Cord: 步骤 5 中的图像 1,3 How to Reattach a North Face Backpack Bungee Cord: 步骤 5 中的图像 2,3 How to Reattach a North Face Backpack Bungee Cord: 步骤 5 中的图像 3,3
      • Tie a knot to prevent the cord from falling through.
      • Tie a second knot, making it a double knot to further secure the end of the cord.
      • Try to get the knot tied at the end of the cord so there is less leftover cord hanging off.
      询问修复机器人
      添加评论
    6. How to Reattach a North Face Backpack Bungee Cord: 步骤 6 中的图像 1,3 How to Reattach a North Face Backpack Bungee Cord: 步骤 6 中的图像 2,3 How to Reattach a North Face Backpack Bungee Cord: 步骤 6 中的图像 3,3
      • Prepare a needle and thread with a double strand.
      • Pull the thread through the hole so it is an equal length on either side of the needle.
      • Cut the thread with enough length to sew up the 2-3 inch opening that was previously cut.
      • Make the thread a little longer than double the length of the opening, so you do not run out while sewing.
      • Tie the ends of the thread in a double knot.
      • Needles are sharp, so be careful. You can use the thimble to protect yourself by putting it on your thumb.
      询问修复机器人
      添加评论
    7. How to Reattach a North Face Backpack Bungee Cord: 步骤 7 中的图像 1,3 How to Reattach a North Face Backpack Bungee Cord: 步骤 7 中的图像 2,3 How to Reattach a North Face Backpack Bungee Cord: 步骤 7 中的图像 3,3
      • Sew the fabric layer back together using a mattress stitch.
      • To do this, insert the needle horizontally across the two layers of fabric and pull the thread through to stitch them together.
      • Repeat the steps moving across the opening in the fabric.
      询问修复机器人
      添加评论
    8. How to Reattach a North Face Backpack Bungee Cord: 步骤 8 中的图像 1,2 How to Reattach a North Face Backpack Bungee Cord: 步骤 8 中的图像 2,2
      • Fold the fabric over the first round of stitches.
      • Complete another pass of mattress stitch to cover the seam and make it more secure.
      • You might want someone to help you hold the folded fabric while you finish up stitching.
      询问修复机器人
      添加评论
    9. How to Reattach a North Face Backpack Bungee Cord: 步骤 9 中的图像 1,3 How to Reattach a North Face Backpack Bungee Cord: 步骤 9 中的图像 2,3 How to Reattach a North Face Backpack Bungee Cord: 步骤 9 中的图像 3,3
      • Make a knot with the string to finish off the stitching.
      • After knotting, use the scissors to cut the string to close it off.
      询问修复机器人
      添加评论
    10. How to Reattach a North Face Backpack Bungee Cord: 步骤 10 中的图像 1,2 How to Reattach a North Face Backpack Bungee Cord: 步骤 10 中的图像 2,2
      • Check your work by tugging on the cord from the outside.
      询问修复机器人
      添加评论
终点
取消:我没有完成这个指南。
Hannah Swope
于05/12/25注册
181 声望
撰写一个指南
团队
UC Davis, Team 3-1, Whithaus Spring 2025 UC Davis, Team 3-1, Whithaus Spring 2025 的会员
UCD-WHITHAUS-S25S3G1
4 名成员
创作了3篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 51
过去 7 天: 244
过去 30 天: 860
总计 5,504
