跳转到主内容
How to Reattach a Cabinet's Center Stile
你所需要的
  1. How to Reattach a Cabinet's Center Stile, How to Reattach a Cabinet's Center Stile: 步骤 1 中的图像 1,3 How to Reattach a Cabinet's Center Stile, How to Reattach a Cabinet's Center Stile: 步骤 1 中的图像 2,3 How to Reattach a Cabinet's Center Stile, How to Reattach a Cabinet's Center Stile: 步骤 1 中的图像 3,3
    • Measure the width and length of the detached center stile.
  2. How to Reattach a Cabinet's Center Stile: 步骤 2 中的图像 1,3 How to Reattach a Cabinet's Center Stile: 步骤 2 中的图像 2,3 How to Reattach a Cabinet's Center Stile: 步骤 2 中的图像 3,3
    • Mark the measurements on the wood block that will be the supporting piece.
    • You may need to extend the length of the new stile to cover several inches above and below the stile's point of attachment.
    • Follow the markings and use the hacksaw to cut down the wood block so that it is the same width as the center stile.
  3. How to Reattach a Cabinet's Center Stile: 步骤 3 中的图像 1,3 How to Reattach a Cabinet's Center Stile: 步骤 3 中的图像 2,3 How to Reattach a Cabinet's Center Stile: 步骤 3 中的图像 3,3
    • Apply a generous amount of wood glue to one side of the wood block.
    • Spread the glue to cover the entire side of the wood.
  4. How to Reattach a Cabinet's Center Stile: 步骤 4 中的图像 1,2 How to Reattach a Cabinet's Center Stile: 步骤 4 中的图像 2,2
    • Place the wood piece against the back of stile and cabinet frame.
    • Use clamps to hold the center stile, cabinet frame, and wood supporting piece together.
    • The clamps prevent the wood block from sliding off the center stile so that it will dry in a fixed position.
    • Remove the clamps after 24 hours.
终点
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 11
过去 30 天: 76
总计 1,310
